run/brake trunk lights
Can the trunk tail light for an RT be made to run also
- Been liked: 334 times
Re: run/brake trunk lights
Skene Lights say, "You can even convert the stock top case light on the BMW R1200RT model to a combined tail light/flashing brake light."
https://www.skenelights.com/r1200rt-k12 ... stallation
wethead wrote: Can the trunk tail light for an RT be made to run also
Where do you want it to run too ?
Mondeoman
Hahhahahaha, that is so funny....NOT!
Definitely. I have the 49L with brake light upgrade.
I had problem wiring my auxiliary led lights directly.. being a campus system it played up.. as some of the lads I have rode with here can confirm.. best through Ezcam or relay.. hey ho.. lesson learned
Motorbiking is a life, not a hobby. Ride with Pride.
