Question on the 1250engine for 2020 owners
wethead
Post by wethead »
[size=2px]The 1250 engine has been noted for so some peculiar noise...If you own a 2020, have come across any eccentric noise in the engine: like a tik or a pop coming out the exhaust (these are the ones I have seen on the forums [/size]
michaelc2710
Has liked: 10 times
Been liked: 29 times
Re: Question on the 1250engine for 2020 owners
Post by michaelc2710 »
you normally only hear a 'pop' when changing up or down using the pro shift, as it cuts the ignition on the gear change for a split second. Most cars with a DSG (Direct shift) gearbox do the same pops.  It's nothing to worry about and doesn't cause any damage to the bike.
Some people (me included)  like the pops
Talisker
Bike Model and Year: R1250RT LE 2020
Post by Talisker »
I have not heard any eccentric / unexplained, pops or bangs from my 1250.  It has, thus far, behaved in a very civilised manner regardless of manual or quickshifter gear changes.
Peter Baker
Has liked: 14 times
Been liked: 6 times
Post by Peter Baker »
Talisker wrote: I have not heard any eccentric / unexplained, pops or bangs from my 1250.  It has, thus far, behaved in a very civilised manner regardless of manual or quickshifter gear changes.
Same for me :-) Peter
Old Foxy
Has liked: 9 times
Been liked: 19 times
Post by Old Foxy »
I get the occasional "pop" when changing gear (downshift with quickshifter) but nothing else.  Hardly noticeable (I think I only heard it, as I had changed from a K1600 GTL, which was much, much quieter).
Old Foxy
davef1uk
Post by davef1uk »
michaelc2710 wrote: you normally only hear a 'pop' when changing up or down using the pro shift, as it cuts the ignition on the gear change for a split second. Most cars with a DSG (Direct shift) gearbox do the same pops.  It's nothing to worry about and doesn't cause any damage to the bike.
It only bothers me hearing him! :P
Motorbiking is a life, not a hobby.  Ride with Pride.  😜
