I came across this Utube Video of an R90S being built from new parts at Max BMW in the USA.
https://www.youtube.com/watch?v=cmVBNSjjrRo
Interesting and Entertaining R90S Build.
- Been liked: 24 times
Re: Interesting and Entertaining R90S Build.
76 Views to date and no one has anything to say. :grave:
I've just finished watching it! Very interesting. Thanks for posting.
Good to see such thorough bike preparation. Much better than some of the 'restoration' videos.
Airheads are not my thing, but I recognise the heritage that's got us to where we are today.
- Steve398
- Has liked: 282 times
- Been liked: 240 times
I'm rather surprised by the absence of anti-seize compound on any of the various nuts and bolts that may require removal at later date.
When I got my used 2018 model I applied coppaslip to every fairing bolt I could find and unfasten, and some of them were a bit creaky to remove... but I guess that's real world as opposed to a showroom piece, although they did take it out for a test ride in the snow and slush, damned if I would!
Interesting observation Steve as I also am a fan of "Careful" use of thread lube / anti seize such as Coppaslip. However I can't recall ever coming across evidence of anti seize when dismantling a "threaded" factory assembled connection. As far as I know the vast majority of Torque values are given for assembly and tightening of "Dry" threads. The application of an Anti Seize / Thread Lube requires a decrease
to the given Torque value of something like 25% depending on the medium used. Tightening a lubricated threaded assembly to a value given for "dry" assembly risks over tightening and the possibility of component failure.
- Been liked: 334 times
One thing BMW do like using a lot of is screw lock to stop things falling apart.
Our Gee wrote: Interesting observation Steve as I also am a fan of "Careful" use of thread lube / anti seize such as Coppaslip. However I can't recall ever coming across evidence of anti seize when dismantling a "threaded" factory assembled connection. As far as I know the vast majority of Torque values are given for assembly and tightening of "Dry" threads. The application of an Anti Seize / Thread Lube requires a decrease
Agree regards dry threads and torque values. I prefer to use ACF50 Block Grease on threads and generally reduce the torque by 10% and round down. So far never had an issue.
- Steve398
I’ve only recently discovered the ACF grease which I’m now using in preference to Copperslip, and fully also agree/accept your point of decreasing the torque values when it’s applied too.
