Servicing - Dealer, Independent or DIY.
Has liked: 68 times
Been liked: 99 times
Re: Servicing - Dealer, Independent or DIY.
Ganesh wrote: Just had the 30,000 and annual service from the local dealer.
Think it's reasonable value for money and as I haven't got a full tool set or some of .
How much was it If you don't mind me asking?
Ganesh
Post by Ganesh »
They did it as a special as the workshop was a bit quiet and the bike is over 5 years old, it all came to £250 parts and labour.
thanks and regards, Ganesh
Been liked: 334 times
Done some DIY servicing today. Checked valve clearances, replaced spark plugs & air filter and changed gearbox oil.
Our Gee
Been liked: 24 times
Post by Our Gee »
David. wrote: Done some DIY servicing today. Checked valve clearances, replaced spark plugs & air filter and changed gearbox oil.
That's a shame. it where a grand day for a ride out.  :kacsint2:
Has liked: 25 times
Post by Sullivj »
Presumably, the valve clearances were still OK?
Levisp
Post by Levisp »
Good days work David before it gets cold. Did mine a week ago. Good to see my valve clearances were still all within specification at 50k. Just one job left to do before winter sets in and that's check and lube the pesky exhaust valve.
Sullivj wrote:Presumably, the valve clearances were still OK.
Yes, after another 5,350 miles, there was no change in the clearances and all were within spec.
Levisp wrote:Just one job left to do.
Still got to change the rear wheel drive oil (180ml). Although this isn't due until 43K or next year, decided to do it early and bring it inline with the gearbox oil (700ml),  1 litre does both.
The BMW dealer will be doing an oil & filter change plus engine synchronisation next week.
David. wrote:Still got to change the rear wheel drive oil (180ml).
Done, plus F&R brake calipers removed, pistons and pads cleaned.
David. wrote:The BMW dealer will be doing an oil & filter change plus engine synchronisation next week.
Bike collected this morning FOC by Vertu BMW Motorrad at Sunderland.
futterweasel
Post by futterweasel »
RTman10 wrote: Fair enough. To be honest with the cost of the bikes in my opinion its not worth the risk taking it out of the dealer network to save a few quid on servicing costs. I spent over 7 years as a Parts Manager in a BMW dealership and saw some horrors on work done by independents. But each to his own.
I had a new engine fitted under warranty at Lind Norwich after four years I decided to remove the crash bars that were fitted and refitted by them that's when I found out one of the main engine bolts had been crammed in cross threaded needles to say the bike has never been back >:( would never use main dealer or independent all service work is easy for the home mechanic, and you know the job has been done correctly see my previous posts for other Lind errors.
hammo
Been liked: 20 times
Post by hammo »
Why did you not return the bike and file a complaint ?
Been liked: 194 times
hammo wrote: Why did you not return the bike and file a complaint ?
He only found out 4 years after the service.
