Hello folks looking for some help, when I bought my RT it came with spot lights. I think they are just a cheap set from ebay or something. They look good and give a good beam, my problem is the push button switch. Press once low beam, press again off, press again high beam then off and the 3rd time it strobes, do you think it is the switch that makes it strobe or will it be built into lights? The bike is a converted RTP, its a 56 plate cheers Paul
Sent from my SM-G960F using Tapatalk
Spot lights
- Been liked: 2 times
Re: Spot lights
Built into the light housing? Or somewhere else? I will have a look at the weekend if weather is bettersakm wrote: I would suspect that there is some sort of controller somewhere
- sakm
- Has liked: 456 times
- Been liked: 399 times
Re: Spot lights
Backofbeyond wrote: Built into the light housing? Or somewhere else? I will have a look at the weekend if weather is better
Well I was thinking external but looking at these https://www.amazon.co.uk/Motorcycle-Hea ... B07GSSVWQQ there is no external controller and they look similar
- Has liked: 911 times
- Been liked: 239 times
Re: Spot lights
The functions is built-in. If you look through YT there are a couple of tutorials of how to stop the strobing. You will need to unsolder 2 contacts.
