Tyre Air Compressor
Our Gee
Been liked: 24 times
Tyre Air Compressor
Post by Our Gee »
Just in the process of prepping the RT for a return to the roads in April. First problem. Trying to remove my Air Compressor from the compartment behind the pillion seat lock it had become stuck. (It was a tight squeeze when sliding it in there). Eventually I managed to retrieve it but obviously it would be a bad idea to re-place it in the same place.
Question. Can anyone recommend a compressor which will fit in the said compartment (Twin Cam). There are numerous compressors available but no one seems to give the all important dimensions.
Thanks.
Has liked: 913 times
Been liked: 240 times
Re: Tyre Air Compressor
I've not got a twin cam but i can fit an Airman tour in the same area
Been liked: 337 times
I've got a Slime tyre inflator, Motorcycle Power Sport Tire Inflator | Slime – Slime Products
From what I can see, this is the closest to mine. The dimensions are, rigid carrying case for easy storage (6.25” H x 6.25” W x 2.25” D).
Forgot to add the AirMan Tour size. 148 x 122 x 61mm. (5.82 x 4,80 x 2.40) and weight is 540g. Sells between £22.99 and £24.99 Comes with 3 types of leads, a Cigarette plug with leads, battery leads and crocodile clip leads, and a drawstring bag.
http://www.airman-uk.com/product/tour-adventure-compressor/
sakm
Has liked: 463 times
Been liked: 407 times
Post by sakm »
When I was looking for one I got one of these
https://www.amazon.co.uk/AA-Inflator-Co ... C66&sr=8-6
its one of the smallest you can find [size=small]11 x 13 x 5 cm[/size][size=small] [/size]
[size=small]
[/size]
[size=small]I changed the connector for one I can plug in to my optimate charging lead [/size]
Our Gee
Post by Our Gee »
Many thanks for the replies chaps. Decided to go with the one recommended by Sakm. Ordered on Friday, delivered today. Really neat and compact design, "easily" slides in the space behind the pillion seat locking catch. Bargain price of £12.20 delivered.
sakm
Post by sakm »
Our Gee wrote: Many thanks for the replies chaps. Decided to go with the one recommended by Sakm. Ordered on Friday, delivered today. Really neat and compact design, "easily" slides in the space behind the pillion seat locking catch. Bargain price of £12.20 delivered.
Good to hear
One thing to make sure though before you get caught out is that whatever you plug it in to can supply enough amps without tripping out!
The first time I used it was connected to my optimate lead and it blew the fuse! which I think was a 7.5A I replaced it with a 10A and all is well
Our Gee
Post by Our Gee »
Thanks for the warning Sakm, I have an extra socket on the rear fairing below the pillion area, which is wired directly to the battery. There is an inline fuse so I will check the rating tomorrow.
Our Gee
Post by Our Gee »
Fuse rating is 15amp so all good to go.
Sure the accessory plugs are rated at 10A for older models and 5A for newer ones. I know before i fitted a lead directly to the battery that the pump tripped the Cambus after a few seconds. Using higher rated fuses is not a wise thing to do
sakm
Post by sakm »
Doctor T wrote: Sure the accessory plugs are rated at 10A for older models and 5A for newer ones. I know before i fitted a lead directly to the battery that the pump tripped the Cambus after a few seconds. Using higher rated fuses is not a wise thing to do
My 2016 is 10A total for all sockets
But I run mine of the optimate charging cable
Doctor T wrote:Using higher rated fuses is not a wise thing to do.
No fuses are fitted in the CAN-bus network.
Doctor T wrote:I fitted a lead directly to the battery.
Optimate leads are supplied with a 15A fuse.
The Slime compressor requires a 15A fuse, whereas, you'll get away with 10A for both the airMAN and AA units.
David. wrote: No fuses are fitted in the CAN-bus network.
I meant the power lead inline fuse.
sakm
Post by sakm »
David. wrote: Optimate leads are supplied with a 15A fuse.
Not all are!
My optimate 3sp had a 7.5A fuse some are known to have a 10A fuse too so best to check what is in there and check what is required for the compressor
The AA one requires a max 10A fuse there no "getting away with it" thats what it needs
