TB sync
Has liked: 901 times
Been liked: 239 times
TB sync
Bike 2007 R1200rt. Am going to sync my throttle bodies tomorrow. I've done this on all my old bikes but never a Throttle body, all the rest were carbs. Viewed a few videos on YT and it looks straightforward job. The only thing i can't find out is what should the tic over be set at. I can take a guess at around the 1150 mark but my OCD would like to get it spot on. Do you know the tic over rev's?.
Has liked: 68 times
Been liked: 98 times
Re: TB sync
Im pretty sure the idle speed is set by the ECU... there are some videos on balancing the throttle bodies on YouTube with a watch.
Been liked: 333 times
Re: TB sync
Doctor T wrote:The only thing I can't find out is what should the tic over be set at. I can take a guess at around the 1150 mark but my OCD would like to get it spot on. Do you know the tic over rev's?
The Haynes manual gives an engine idle speed of 1100 to 1200 rpm.
Re: TB sync
simbo wrote:I'm pretty sure the idle speed is set by the ECU.
You are correct, "Notice I do not do an idle sync as on the R1200 it is not possible. Nor is it possible to adjust the idle speed. This is all done via the stepper motors by the computer (ECU)."
BMW R1200GS / R1200 Throttle Body Synchronisation (Synchronization) (motorcycleinfo.co.uk)
Re: TB sync
Thanks, chaps. Couldn't find the idle screws show on some YT videos. So as pointed out it must be controlled by the ECU. The right side needed a tiny adjustment, which i did by adjusting the throttle cable. I left a 5mm play in the cables. Didn't really need to do but am fussy. I must say even that tiny adjustment makes the tic over feel better.
Before anyone says i checked the valves just over 250 miles ago but just double-checked again before balancing.
Couple more questions.
Do the valve gaps go out of range between service schedules?
My throttle cables were changed at the last BMW service, approx 700 miles ago. Do these cables stretch a lot, requiring TB sync every few thousand?
Although ive owned many boxers in the past, all were carb models so am a newbie with Boxer throttle bodies and their cable setups.
My first taste of TB was with my old 2007 which i never touched as it was under 3 years old when it was nicked. Thinking of it my K75 had TB but again that was only serviced by BMW.
