Crud Catcher by Cymarc Engineering
beemerbaz
Post by beemerbaz »
I have one of these on my RT to help protect the front engine casing. Mine was powder coated black to match the bike.
http://www.cymarcbikeparts.co.uk/bmw-r1200rt-front-crud-catcher-53-p.asp
Re: Crud Catcher by Cymarc Engineering
One thing to ponder about this if fitted to a 2014 model. Behind the front cover on a pre 2014 RT there is not much more than the bottom pully for the alternator. On the 2014 its a wet clutch. Just thinking that it probably relies a little on the air flow over the cover which it wont get with the catcher fitted. For that reason alone I will be looking at a fender extender.
Maz12
Post by Maz12 »
I was thinking the same  and will also go for the Fender Extender
Pope
Post by Pope »
Belt and Braces.......
Cymark and Exdender working in perfect harmony..
beemerbaz
Post by beemerbaz »
Had mine on a year now with the Fender Extender also with no issues except a rather cleaner engine [emoji106]
Steveeung
Post by Steveeung »
I have just fitted the same set up to my 1200 LE and haven't ridden it yet (fitted tonight) but it does look as if the extender will hit the crud catcher when the shocks bounce. Will let you know ... :eek:
I notice Pope's pic has the motif RT on it. Mine has nothing but it is made by Cymark.
RT LE, San Marino Blue, Cee Bailey Screen, Nav IV, Hornig horn, Aux Lights, Michelin Pilot Road 4GT, Crud Deflector, Fender Ext
Pope
Post by Pope »
Steveeung wrote: I have just fitted the same set up to my 1200 LE and haven't ridden it yet (fitted tonight) but it does look as if the extender will hit the crud catcher when the shocks bounce. Will let you know ... :eek:
No problems with clearances here. And remember, there is very little front dive, due to the Tele-Lever system.
BTW, i asked for the RT logo to be added on mine (no cost option).
Steveeung
Post by Steveeung »
You are so right - works a treat - thanks!    C:-)
