Recently purchased some Comma EP80W-90 GL-4 for the XJ650 FD unit, it has a shelf life of 5 years from date of manufacture.simbo wrote:Will you be using what's left in the bottle in the final drive? Be a shame to see it sat on the shelf for the next 12 months.
Gearbox Oil Twincam RT
- Been liked: 334 times
Re: Gearbox Oil Twincam RT
I see just to confuse matters, Castrol have changed the name and packaging again, Castrol Transmax Axle Long Life 75W-90 (Formerly SAF-XO 75W-90 and Syntrax Longlife 75W-90).David. wrote:I use the Castrol Syntrax Longlife 75w-90 (Formerly SAF-XO 75w-90) in the gearbox & final drive.
As confirmed by Motorworks, Motorworks BMW Motorcycle Specialists - Shop - Spares and Accessories
Have recently been looking for some Castrol Transmax Axle Long Life 75W-90, it's currently out of stock at OPIE Oils, Motorworks and Nippy Normans.
Please can anyone recommend a UK supplier or suggest a suitable alternative, thank you.
Liqui Moly looks like a good alternative, https://www.infinitymotorcycles.com/pro ... atch%20All
- sakm
- Has liked: 460 times
- Been liked: 403 times
Amazon?David. wrote: ↑Sun Oct 16, 2022 10:40 am Have recently been looking for some Castrol Transmax Axle Long Life 75W-90, it's currently out of stock at OPIE Oils, Motorworks and Nippy Normans.
Is this the same
https://www.amazon.co.uk/Castrol-Syntra ... =8-1-fkmr0
No, I don't think so, Castrol do three variants of Transmax, ATF, Manual & Axle, https://www.castrol.com/en_gb/united-ki ... nsmax.htmlsakm wrote: ↑Sun Oct 16, 2022 12:07 pmIs this the same.
Axle Long Life is the spec. required, https://msdspds.castrol.com/bpglis/Fusi ... az3hzs.pdf
- sakm
I'm not at home at the minute but what's the actual spec that the service manual asks for?
Transmax universal says its for transmissions final drives and differentials and I'm pretty sure that meets the spec so maybe check that one out
The BMW service parts list asks for BMW Synthetic OSP which is equivalent to SAF-XO as per the Haynes Manual.
https://www.deutsche-parts.co.uk/331176 ... -part.html
This is the SAF-XO data sheet, https://www.ge39.com/files/SAF_XO_SAF_XJ_B1174_96.pdf
Over the years, Castrol have re-branded SAF-XO > Syntrax > Transmax Axle.
This is the Transmax Axle data sheet, https://msdspds.castrol.com/bpglis/Fusi ... az3hzs.pdf
Both the SAF-XO and Transmax Axle specs. look the same.
- sakm
apparently this is the replacement for Castrol 75W-90 C-SAF-XO if it helps at all
https://classicoilsshop.co.uk/castrol-syntrax-75w90
I would agree that Syntrax replaced SAF-XO but Castrol seem to have now changed Syntrax to Transmax Axle.
https://www.motorworks.co.uk/gear-oil-oia11056-1.html
Just spotted that Motorworks do list some alternatives.
- sakm
I have dropped Castrol an email to see what they say
I suspect whatever you use as long as it meets the spec it will be more than good enough
It would be interesting to know why Transmax Axle is currently out of stock.
I'm sure you a right but if available, would rather use the BMW recommended Castrol stuff.
This is the current Castrol recommendation, https://www.castrol.com/en_gb/united-ki ... haft-drive select "Shaft Drive".
This would seem to confirm that Red Line 75W90 meets the BMW SAF-XO spec. too, although more expensive from the USA.
