I have fitted a Booster Plug to my R1250 RT (2019model). To be honest, I have not noticed much improvement in driveability.
Now we are getting to the cooler months, I notice that on starting, the exhaust smells much richer than normal.
Should I remove the Booster Plug during the colder months?
Thanks.
Booster Plug removal for cold weather?
- Been liked: 477 times
Re: Booster Plug removal for cold weather?
Having read this, https://www.boosterplug.com/shop/cms-ho ... rsion.html the answer would be no, leave the BP fitted.Tony Fyson wrote: ↑Sun Nov 27, 2022 5:02 pm Should I remove the Booster Plug during the colder months.
"With the BoosterPlug, you will get a 6% richer mixture regardless of the temperature conditions you're riding in."
- walstibsf
- Bike Model and Year: 2019 R1250RT
- Has liked: 2 times
- Been liked: 2 times
Tony, what neck of the woods do you live in? I'm thinking if you live at altitude, you may not experience the full effect others living at lower altitudes do from the boosterplug.
Thoughts?
V/R
Bobby
Thoughts?
V/R
Bobby
W A L S T I B....S F ...
What A Long Strange Trip It's Been...So Far
Hi Bobby
I live almost at sea level, in north Devon.
My highest hills are about 1000 foot above sea level.
- Has liked: 1434 times
- Been liked: 406 times
Booster plugs fool the ecu into thinking the outside temperature is lower than it is. This will increase the fuel/air mixture, hence why you get a fuel smell.Tony Fyson wrote: ↑Sun Nov 27, 2022 5:02 pm I have fitted a Booster Plug to my R1250 RT (2019model). To be honest, I have not noticed much improvement in driveability.
Thanks.
(I made a DIY booster plug. Cost under £5 for my RE Himalayan. These bikes run very lean. MPG dropped to 80 from 90 MPH.)
The Booster plug fools the ecu by thinking it is 20 degrees lower than it is. Personally unless you have a snatchy throttle or a ruff tic over i wouldn't bother with one. If you're using one to get more power, this will not work
