Shaft Replacements
Re: Shaft Replacements
Will do. But doubt if he will bother creating an account on here, he probably has better things to do than converse with Mr Google, unlike me obviously :)
Been liked: 337 times
Casbar wrote: Fri Dec 02, 2022 12:00 pm Will do.
Thank you Robert, very much appreciated, nice to do business with you as always.
I look forward to his and/or your feedback, regards David.
Casbar wrote: Thu Dec 01, 2022 10:58 pmNot interested in getting into a google debate.
I wouldn't bother with them either, you won't get any sense out of Google.
David and Sally
Has liked: 12 times
Been liked: 16 times
Post by David and Sally »
This is the reply I got from my local Motorrad dealer when I asked about my R1250RT
Good afternoon
Thank you for your email.
There are currently no recalls or quality enhancements outstanding on your bike. The shaft vent campaign has only been released on GS and GSAs so this wont be released on your bike.
Kind regards
Matt
sakm
Has liked: 462 times
Post by sakm »
Thinking out loud here I could see that the shaft rotation could cause pressure due to heat which could push air out past the gaiters.
Then when it cools would then cause a vacuum which is what could be bringing in moisture
As for the valve and if its one way or not god knows! Without getting hold of a valve and studying it we would all be guessing
Ideally it needs to be two way to allow air in when the vacuum happens
That's my theory anyway :lol:
David and Sally wrote: Fri Dec 02, 2022 1:28 pm The shaft vent campaign has only been released on GS and GSAs, so this won't be released on your bike.
If you believe BikeSocial at Bennetts (and I don't), "the update only applies to the GS and to rare ‘official use’ versions of the R1200RT and R1250RT – the sort sold to police or perhaps blood bike services."
Possibly why a "civvy" RT isn't included.
I know someone with a pre-Oct 21 GS and his requires the shaft vent valve retrofitting.
sakm wrote: Fri Dec 02, 2022 1:33 pm As for the valve and if it's one way or not God knows! Without getting hold of a valve and studying it we would all be guessing.
I'm guessing from this photo that it's one way and BikeSocial say it is, so, it's got to be true.
"All get a vent hole drilled into the lowest point of the shaft drive assembly’s outer case, and bunged with a rubber one-way valve that allows water to be drained from inside without letting water in."
This photo shows a 2022 GS where the vent valve has disappeared inside the swing arm. (Might have been sucked in under vacuum).
Doesn't look like a very secure solution and this was factory fit. (Now it's a two way valve).
This is what it should look like.
P.S. Defo. looks like a one way valve!
Don't thank me, thank Google, correction, my web browser is Microsoft Edge.
7vwh
Has liked: 12 times
Been liked: 33 times
Post by 7vwh »
On Monday I’m gonna pull the rubber thingamejob out of our RTp and see what it looks like for the sake of this discussion lol
Apparently, the shafts are being replaced on LC 1200's & 1250's because during the design and manufacturing process, the swing arm and final drive unit has been fitted on the wrong side of the bike. Unlike the pre-LC vintage bikes which don't suffer from this particular problem.
The source of this information cannot be published but is neither Google, MicroSoft Bing nor Encyclopedia Britannica.
Has liked: 69 times
Been liked: 99 times
David. wrote: Mon Dec 05, 2022 5:43 pm Apparently, the shafts are being replaced on LC 1200's & 1250's because during the design and manufacturing process, the swing arm and final drive unit has been fitted on the wrong side of the bike. Unlike the pre-LC vintage bikes which don't suffer from this particular problem.
I knew you had a sense of humour in there somewhere :thumb: I gathered that from the bike you ride :lol:
Has liked: 46 times
Been liked: 42 times
simbo wrote: Mon Dec 05, 2022 8:43 pm
I knew it from the camouflaged wheel wieghts.
