Which fuel
- Bike Model and Year: 2005 R1200rt
- Has liked: 11 times
- Been liked: 6 times
Re: Which fuel
Cheers. I was just looking for which people would recommend? Does the bike respond well to premium or not? In my experience some vehicles thrive on it and some don't.
- Been liked: 337 times
Re: Which fuel
Most of the time, I use Tesco Momentum 99 (E5). IMO, it's unlikely you'll feel any performance difference but may see better MPG. Then there is the debate between supermarket fuel and branded (E5 or E10).
Some further discussion in this Fuel Grade thread, viewtopic.php?t=1252&hilit=fuel+grade
- Steve398
- Has liked: 285 times
- Been liked: 241 times
Re: Which fuel
I used the posh stuff until the prices went crazy then I went to standard, tbh I don’t notice the difference other than at the till!
- sakm
- Has liked: 463 times
- Been liked: 407 times
Re: Which fuel
Run on normal E10
Your bike needs to be tuned to 99 octane fuel to get the best out of it
I have used both and can tell no difference
- sakm
Re: Which fuel
A full tank f high octane fuel and a day on a dyno and someone tweaking the fuel maps and timing to get the best out of the fuel and bike
But for our bikes it's not worth it as the gains for road use are not really seen
Re: Which fuel
Just dug out some guidelines I was given before taking my Camhead to be remapped.
"Super unleaded fuel - unless your bike's manual specifies that the engine will give maximum performance on super unleaded, there is no benefit to filling up with super unleaded before your visit. We tune to standard 95RON fuel as it's commonly avialble. That doesn't mean you shouldn't use super unleaded where possible, as it often has other benefits such as better detergents and less ethanol than standard fuel, but you won't get more power with our tune from doing so."
Other engine tuners may have a different opinion.
AFAIK, octane rating is determined by the engine compression ratio and doesn't enhance performance. However, using a lower than specified octane ratio may cause pre-ignition/pinking. Modern bikes have anti-knock sensors, hence the Camhead and Hexhead being capable of running on lower octane fuel.
