I can’t help thinking the switchgear / buttons and wonderwheel on my 2019 RT feel a bit clicky and well…cheap . I’ve tried a small squirt of a silicone spray which won’t hurt plastics but doesn’t really do anything.
Is there something on the market which might lube the various switches and buttons so they feel a little smoother ?.
Switchgear and buttons lube ?
- Been liked: 341 times
Re: Switchgear and buttons lube ?
This is typically what the internals of a combination switch look like. (Ignore the white wire, that is a repair).
I'm not really sure that lubricating the switchgear actually achieves anything other than the plastic switch or button within the cover.
- Bike Model and Year: 2020 R1250RT
- Has liked: 99 times
- Been liked: 55 times
It's most likely the action of the microswitches behind the buttons that feels cheap usually as a result of platic dust from using the switch itself. These microswitches can have a waterproof cover so spraying from the outside might not help. WD40 in my experience is great at first but dries out into a white powder eventually which can give it's own problems.Panman40 wrote: ↑Sat Feb 25, 2023 7:37 am I can’t help thinking the switchgear / buttons and wonderwheel on my 2019 RT feel a bit clicky and well…cheap . I’ve tried a small squirt of a silicone spray which won’t hurt plastics but doesn’t really do anything.
- Bike Model and Year: R1250RT 2021
- Has liked: 25 times
- Been liked: 29 times
Personal and very humble opinion - I wouldn't let WD40 anywhere near plastics/nylon or delicate low voltage/low pressure switchgear. Being a fairly mild solvent it leeches colour, leaves a residue which isn't very kind to electrical contacts, can damage solder joints and in some plastics but mostly in nylon casings, can cause swelling enough to lead to movement being stalled. It was always fine to use it in the distributor of the Morris Minor but - those days on our bikes are gone - sadly.
A brief spray with a fast drying fairly astringent solvent seems to perform better with a spray of silicon to follow for re-lubrication.
Working out how to get at the internals that feel 'not right' without causing inadvertent damage is the real issue.
My preference is to apply repeated sprays of silicon as deep into any switchgear cracks/joints that I can see in the hope that some of it gets through.
I have to admit that my motto is that if it's not actually broken - don't try to actually fix it!
Never had any switchgear jam up though I do agree that sometimes the whizzwheel on my '21 RT does feel a bit cheap and the menu and direction indicator buttons can seem 'sticky' in operation.
- Bike Model and Year: R1200RT 2012
- Has liked: 3 times
I use the WD40 specialist range contact cleaner, I had an issue with the cruise control switch not working. Used the contact cleaner and its been fine ever since for the last five years or so. so gets my vote.
63 plate Camhead RT SE with NAV 5, 22l topbox, rear panniers with flat lids, RTP cooling fan, LED side lights, headlight protector, grip puppies, RTP engine bars. Stage 1 remap, sport end can, last of the air/oil cooled RT model.
- Been liked: 24 times
That's interesting, as the "Slide Across" cruise switch on my own 2011 Twincam is quite stiff and not that positive. Did you disassemble the switch to apply the Contact Cleaner or just give it a squirt externally ?. Thanks.Cornish_Camhead wrote: ↑Mon Feb 27, 2023 10:37 pm I use the WD40 specialist range contact cleaner, I had an issue with the cruise control switch not working. Used the contact cleaner and its been fine ever since for the last five years or so. so gets my vote.
"In this video I disassemble and re-assemble/teardown the left hand multifunction switch from my 2014 K52 R1200RT."
Found this thread on Adventure Rider, https://www.advrider.com/f/threads/2013 ... r.1251430/
"I removed the turn signal kill button, cleaned it and it's working again.
The only problem I'm running into now is trying to figure out the epoxy or resin used to weatherproof the buttons to the circuit board.
Notice the button with the arrow. I had to remove this to remove water damage and clean the contacts. Notice the resin around it that needs to be resealed."
Hi our gee, I didn't disassemble anything, I just gave all the switchgear nooks and crannies a good blasting and operated the switches etc.
The product says on the tin its rubber and plastic compliant and I've had no issues since, I tend to do this after either washing the bike or when I've ridden in the rain etc as a sort of preventative maintenance.
