Just serviced my 07. All fluids except the brake and clutch as i changed them last March.
Old age must be setting in because i can't remember how much oil the rear drive bevel takes. I think it's something like 80Ml and the same oil as the gearbox. The oil looks quite clean seeing ive clocked up 13000 miles since last March, just needs replenishing now.
Rear bevel oil
- Has liked: 911 times
- Been liked: 239 times
Re: Rear bevel oil
Cheers, Stu. I thought there was a 80 in there somewhere
- Been liked: 334 times
Re: Rear bevel oil
The Haynes manual for a Hexhead doesn't give a FD oil capacity because at the time, it was changed at 600 miles then in for life.
For a Camhead, it's 180 ml, it'll likely be the same for a Hexhead.
Re: Rear bevel oil
The original spec. gearbox oil for a Hexhead was SAE 90 and the FD was the fancy 75W-90.
Re: Rear bevel oil
Cheers David. So gearbox is the same as rear drive as i thought
- sakm
- Has liked: 457 times
- Been liked: 402 times
Re: Rear bevel oil
here you go
180ml
180ml
- 2007 rear drive.pdf
- (479.89 KiB) Downloaded 103 times
Re: Rear bevel oil
What is that from?, it's not Haynes
Re: Rear bevel oil
Mine has a drain and fill plugs. As he said mine must have been replaced at some time.I will look through the service history as am sure it has something about a warranty claim for bevel and shaft
Re: Rear bevel oil
My 2007 Hexhead was as per the video, FD oil changed at 600 miles then never again.
Re: Rear bevel oil
Thanks Glenn
- sakm
Re: Rear bevel oil
Its the BMW RSD manual which covers pretty much all models
Its apparently what BMW use
Re: Rear bevel oil
Where can i get it from
All back together, renewed oil, splines grease
Thanks for the help chaps
