Auxiliary light brackets
Has liked: 620 times
I have ordered some heed engine bars and I need to remove the auxiliary light brackets and replace them with something else
Anyone got any recommendations? particularly ones that will fit the BMW lights on
I have seen some lights mounted between the fairing under the front light which looked good but can't find any brackets for them :?
Glacial
Has liked: 3 times
Been liked: 8 times
Re: Auxiliary light brackets
Post by Glacial »
Glacial wrote: Tue Apr 25, 2023 10:25 pm Try this?
https://www.ebay.co.uk/itm/185301338240 ... media=COPY
Thanks but mine is a 2016 model
Has liked: 1433 times
Denali does mounts that fit just below the mirrors but a bit expensive at £116. Also there is Heed and Givi. I think Wunderlich do some
Has liked: 473 times
Been liked: 404 times
Yeah the denali ones are a bit on the steep side!
By the looks of it I will be fitting them to the engine bars using something like what Steve linked to
Been liked: 46 times
I have Illium brackets. But again not a cheap option. Sportouring are a uk supplier
Found some but not sure if I like the position they are in!
I wanted them higher or in a similar position to the standard ones but the brackets and bar combination just won't allow that position!
Am I being too picky? :lol:
If they stay there I will need to extend the wiring
Has liked: 617 times
sakm wrote: Tue May 02, 2023 8:47 pm Found some but not sure if I like the position they are in!
Will they not fit on the top part of the bar ? .
Panman40 wrote: Thu May 04, 2023 6:35 am Will they not fit on the top part of the bar ? .
Not really!
The brackets are pretty big and can't get the correct angles due to fouling with the engine
Plus the rear of the lights touch the engine too
Here are mine on the Illium brackets, they are full adjustable on all planes.
Casbar wrote: Thu May 04, 2023 12:42 pm Here are mine on the Illium brackets, they are full adjustable on all planes. IMG_4147.JPG
If I had a bar as far forward as yours I would be OK
Doctor T wrote: Fri May 05, 2023 4:09 pm What about these?eBay item number:185802988180
These are the ones I bought already
They fit and work I'm just not sure if I am happy with the position
Ps the links didn’t work so I just used the item number :thumb:
Extended the wiring for the lights the other night!
I went the whole hog and removed the loom for the lights and extended them at the top end where it is all hidden and taped it all back up and it looks stock! well what you can see of it anyway
Lights look OK where they are now they work :lol:
