Sat Nav eject button sticking
audibob2
Bike Model and Year: 2015 R1200rt
Been liked: 14 times
Post by audibob2 »
My sat nav eject button is sticking.
Can I access it by removing the screen and the top plate ?
Re: Sat Nav eject button sticking
Yes you can :thumb:
Been liked: 46 times
Known issue as the weather gets colder, it's only plastic. I used to just spray silicon spray on it, although it would always depress, but not spring back, so just used to us my finger to reset it. But yes you can get to it if you remove the screen and the top cowling
audibob2
Post by audibob2 »
what is with those stupid plastic screws at the bottom of the cover on the sat nav eject cradle. What screwdriver bit will fit , can they be replaced with metal screws?
I just use a small straight screwdriver for those
scunny12
Has liked: 42 times
Been liked: 49 times
Post by scunny12 »
Having watched my Navigator pop out twice whilst riding ( luckily caught it before falling to the ground ) I too am liberal with the silicone spray to make sure eject system slides better. :roll:
audibob2
Post by audibob2 »
Why did bmw choose to use plastic screws on the bottom of the sat nav cradle cover?
Do they have plastic nuts behind, and can you use metal fasteners instead?
Might grind down a suitable size phillips screwdriver to get them out.
Been the same since 2014, has never cause any issues on 2 bikes, or 5 fleet bikes. So guess they do the job fine, its not like you take the cowling off every week.
gadgetgaz
Post by gadgetgaz »
If you loosen the two screws on the top of the cowling you can manipulate the cowling by pushing and pulling until the button pops out. Then tighten the screws back up with the cowling in this new "position".
2023 R1205RT LE Sport Blue. IT consultant, retired bike cop and RoSPA RoADAR examiner.
kwadge
Bike Model and Year: R1250RT LE
Post by kwadge »
Whilst looking at this post it got me wondering. As I’ve just fitted a Zumo xt2 with the 3DAM adapter, could this happen on mine. It has been a bit sticky of late. I’m thinking of fitting the Wunderlich locking plate that works off the central locking but I can’t confirm that it will work. Looking at it I can’t see why not but before I commit another lump of cash can anyone advise if they’ve fitted one. I have emailed Wunderlich and they didn’t have a clue what the 3DAM adapter was.
Has liked: 472 times
kwadge wrote: Tue Jan 30, 2024 3:37 pm Whilst looking at this post it got me wondering. As I’ve just fitted a Zumo xt2 with the 3DAM adapter, could this happen on mine. It has been a bit sticky of late. I’m thinking of fitting the Wunderlich locking plate that works off the central locking but I can’t confirm that it will work. Looking at it I can’t see why not but before I commit another lump of cash can anyone advise if they’ve fitted one. I have emailed Wunderlich and they didn’t have a clue what the 3DAM adapter was.
1) Try the Old Timers satnav lock, identical but less expensive.
https://www.oldtimers.si/en/navi-centra ... -2014.html
And a video to show you how to do it.
2) I use a 3DAM adapter with my Tomtom and the O/T lock. I ‘can’ get the Tomtom off the 3DAM while it’s locked, but it’s difficult and tbh I would only leave it on there whilst I paid for petrol, any other time I’ll put it in the pannier.
kwadge
Post by kwadge »
Thanks for the info. As long as the adapter is locked in place I’ll be happier. When in position it is possible to release the Zumo but it’s not easy. I think I can manufacture a cover given some time.
Resurrection of an old thread -
The eject button seems jammed, so can’t get the Carpuride out.
Despite removing the top plastic shield (and dropping one of the plastic screws onto the black rubber matting on the floor, never to be seen again) which has given me access, no amount of heaving, pushing, and cursing copiously will get the poxy thing to come out!
:mad:
Has liked: 225 times
Been liked: 102 times
Had same problem with mine when not that old, but freed without removing anything. Now when wash always use air dryer to dry and operate function without nav or cover a few times and I've never had problem for years. Not saying guaranteed but seems to have solved issue for me, fingers crossed.
Having now removed the whole mount from the dash I saw that the plastic push mechanism had snapped inside of the casing.
The only way to remove the satnav was to cut away the lower mount with a Dremel, the unit now being useless anyway, which allowed the satnav to drop out. In fact the design of the mount has changed slightly from the picture but is fundamentally similar.
Official BMW dealer price £113.
[attachment=0]IMG_6709]
