Can I use this gps mount?
- Bike Model and Year: 2013 BMW R1200RT SE
- Been liked: 2 times
I just bought a 2013 r1200rt se. It’s the outgoing model without water cooling.
It has this GPS mount but no GPS unit. What would you recommend I do with it?
Find a BMW gps to use with it.
Can it be used with a different gps or iPhone.
Should I remove it?
I do want gps but using my iPhone for it has let me down previously in areas with no phone signal. I don’t have much money to spend so anything I need I’ll be looking for on eBay.
Thanks for any advice.
Should I remove it?
- Stu
- Has liked: 623 times
- Been liked: 610 times
Re: Can I use this gps mount?
Personally if it was me I would buy a standalone sat nav like the Garmin or TomTom
There will be plenty of people along soon enough to tell you of the issues of the expensive BMW Nav range and why to avoid it
You should be able to remove the mount and fit a different sat nav there
- Been liked: 480 times
I've now had a Garmin Zumo 660 for 13 years, it's been faultless. A 660 will fit and take power from the BMW mount. The remote buttons will not work.
Whereabouts in the UK are you.
- Been liked: 415 times
I have the same/similar mount on my bike,I use the TomTom rider 550Bikergonebald wrote: ↑Thu Mar 28, 2024 8:06 am I just bought a 2013 r1200rt se. It’s the outgoing model without water cooling.
Should I remove it?
You can get various brackets for different devices to fit whatever you like.I'm buggered if I can remember the name of the set up but I'm convinced it's German.
- Stu
Are you talking about the italian 3DAM adaptor?burridge01 wrote: ↑Thu Mar 28, 2024 1:30 pm
- Stu
Ah you're talking about a mount
I am talking about an adaptor that allows you to mount most sat navs to the nav prep and take its power from there
Like so
Like so
I was talking about both,Hornig covers it all
https://www.google.com/url?sa=t&source= ... D75558Qtm6
Fill ya boots
And I see where you're coming from with that mount.
Fill ya boots
Thanks for all of the replies.
The TomTom 550 and Zumo 660 were mentioned there, I see there are a few of those cheap on eBay. Can the maps still be updated?
- Steve398
- Has liked: 489 times
- Been liked: 412 times
Italian. Here’s mine fitted in the OEM BMW Navigator mount with the adaptor and Tomtom
- Has liked: 17 times
- Been liked: 137 times
That's exactly what I use with my R1250RT and Garmin XT. It looks as OEM as you're going to get.
