Lever plunger ?
- Has liked: 617 times
- Been liked: 106 times
Lever plunger ?
So after swapping my levers over I managed to mess up the tiny 2mm Allen grub screws you have to loosen ( covered in red threadlock) , I thought each part could be purchased separately having read another forum but the dealer said unlikely as it looks like that plunger rod is part of the master cylinder at £385!!.
Anyone know different ?.
- IMG_2632.jpeg (227.47 KiB) Viewed 3677 times
Re: Lever plunger ?
Rounded out the 2mm Allen grub screws as they were very tight with loctite on the brake side, the clutch side was fine. It’s usable but I’d rather replace it.
- Been liked: 476 times
Re: Lever plunger ?
Remove the clutch side, check the size and see if Stig Fasteners have one to fit, https://a2stainless.co.uk/page/1/?s=gru ... pe=product
I've read that they may by M4 x 8mm x 0.7mm pitch.
- Stu
- Has liked: 620 times
- Been liked: 598 times
Re: Lever plunger ?
I believe its all part of the plunger so you can't just replace the grub screwDavid. wrote: ↑Sat May 25, 2024 1:35 pm Remove the clutch side, check the size and see if Stig Fasteners have one to fit, https://a2stainless.co.uk/page/1/?s=gru ... pe=product
- Stu
Re: Lever plunger ?
That makes sense! I would maybe scour ebay and see if you can get a replacement because as you say you can't just replace the plunger
Re: Lever plunger ?
Is it the plunger adjuster or grub screw in the barrel which is rounded out.
If it's the grub screw, this might do the trick, https://a2stainless.co.uk/product/m4-x- ... in-914-a2/
Re: Lever plunger ?
Is this the grub screw in question which needs to be loosened to adjust or remove the plunger.
Adjusting the plunger.
Re: Lever plunger ?
Both!, are you thinking drill them out and try and re tap the threads ?.David. wrote: ↑Sat May 25, 2024 7:20 pm Is it the plunger adjuster or grub screw in the barrel which is rounded out.
Re: Lever plunger ?
Ahh yes your correct, I did adjust it using pliers but marked it up a little, I’m getting careless in my old age
Re: Lever plunger ?
Were the grub screws removed from both the brake and clutch levers, with the plungers being removed and reused in the replacement levers.
Re: Lever plunger ?
Yes, but I couldn’t remove the locking ones, I should of left it at a half turn really it’s a very strange setup to be honest.
Re: Lever plunger ?
I'm confused (easily done), were the plungers removed without removing the grub screws, then screwed back in.
Re: Lever plunger ?
Yes, when I went to tighten the brake grub screw after threading in the plunger it was stuck fast and rounded out the hex. As it happened the thread on the plunger was a little burred so locked off tight when threaded back in.
Re: Lever plunger ?
Could the thread on the plunger be dressed up using a die. The grub screw in the barrel could be drilled out and threads re-tapped, together with the thread for the plunger. Or, drill out both threads and fit Time-Serts to repair the threads. Alternatively, have a new barrel manufactured.
