Can't get tool onto stick coil
montanamax
Post by montanamax »
Trying to change my plugs and I'm having trouble fitting the special tool onto the top of the stick coil. It fits about half way but I can't get it to slide over and completely cover the top. I've looked at various videos and nobody mentions this as a problem In one, the guy smacks the side of it to get it to seat but that's not working for me. I'm thinking of using some lubricant. Any suggestions, tips or tricks? Thanks.
Has liked: 623 times
Been liked: 610 times
Re: Can't get tool onto stick coil
Have you got any photos?
If I remember rightly they do feel like they need to go on more even when fully home
montanamax
Here's the best view of the problem:
Ignore.
That looks fully on to me
Been liked: 480 times
Coil Stick Tool.jpg (6.63 KiB) Viewed 5034 times
See video at 0:23 for use of the tool.
montanamax
The video is helpful and convinces me that I don't have the tool on fully. Still thinking of using some lubricant, maybe a bit of grease.
montanamax
Update - On examining the special tool for removing the stick coil, I discovered a bit of a burr on on side which I think was catching on the coil. I filed it off, used a little bit of grease, and was able to get it on properly and remove the coil. Finally!
