R1250RT Clutch Engagement Spot
omniphil
Post by omniphil »
Hello all,
I am guessing this is probably my first bike with a hydraulic clutch but the engagement spot is too far out for my liking...
I'll had many bikes to compare with and this one seems to be at the very end of the clutch lever. My hands are almost fully open.
For more precise control I'd like it to be closer so my fingers aren't open as much.
I currently have the factory adjustable levers set at "1". If I went with aftermarket levers would this allow me to bring in the engagement zone a little more?
Just wondering if anyone else has noticed this? (I had the dealer look at the clutch during a recent visit and they said it was fine)
Re: R1250RT Clutch Engagement Spot
Yes I had exactly the same issue and I bought the wunderlich levers which bring it closer to the bars
Has liked: 473 times
As have I… nice to know my recommendation worked Stu 👍
omniphil
Post by omniphil »
Anyone have any experience with anything a little cheaper? While I do like Wunderlich, close to 400 a pair seems excessive. I'm also not a fan of the adjustable length mechanism, I'd prefer they be solid pieces. If it's the only quality option out there I'll bite the bullet. Just seems a bit extravagant.
Has liked: 99 times
Been liked: 222 times
There's a little grub screw at the back of the lever you can adjust for the bite point, only turn it in small increments while checking the bite point you require.
simbo wrote: Mon Mar 24, 2025 5:08 pm There's a little grub screw at the back of the lever you can adjust for the bite point, only turn it in small increments while checking the bite point you require.
Unfortunately this doesn't move the point enough! well not in my case anyway
You are talking fractions of an inch and if you're not careful you can end up with clutch slip if adjusted too much
Has liked: 99 times
Stu wrote: Mon Mar 24, 2025 7:03 pm Unfortunately this doesn't move the point enough! well not in my case anyway
I was replying to the OP's question of "anyone have any experience of anything a little cheaper". It's worked for a few members of the ukgs forum so thought it might be worth mentioning. 👍
Has liked: 617 times
I went with the ASV levers from eBay. £243 the pair.
omniphil
Post by omniphil »
I ended up getting some ASV levers. (Right from ASV - which was great because you can pick whatever color you want for the levers and adjustment knobs) They certainly allow plenty of adjustment.
Seems like the cheapest of the good quality levers.
Of note when I got the levers they were the same part number, called ASV and they confirmed that is correct on this bike.
