Which fuel
- Bike Model and Year: 2005 R1200rt
- Has liked: 11 times
- Been liked: 6 times
Re: Which fuel
Cheers. I was just looking for which people would recommend? Does the bike respond well to premium or not? In my experience some vehicles thrive on it and some don't.
- Been liked: 480 times
Re: Which fuel
Most of the time, I use Tesco Momentum 99 (E5). IMO, it's unlikely you'll feel any performance difference but may see better MPG. Then there is the debate between supermarket fuel and branded (E5 or E10).
Some further discussion in this Fuel Grade thread, viewtopic.php?t=1252&hilit=fuel+grade
- Steve398
- Has liked: 489 times
- Been liked: 413 times
Re: Which fuel
I used the posh stuff until the prices went crazy then I went to standard, tbh I don’t notice the difference other than at the till!
- Stu
- Has liked: 624 times
- Been liked: 610 times
Re: Which fuel
Run on normal E10
Your bike needs to be tuned to 99 octane fuel to get the best out of it
I have used both and can tell no difference
- Stu
Re: Which fuel
A full tank f high octane fuel and a day on a dyno and someone tweaking the fuel maps and timing to get the best out of the fuel and bike
But for our bikes it's not worth it as the gains for road use are not really seen
Re: Which fuel
Just dug out some guidelines I was given before taking my Camhead to be remapped.
"Super unleaded fuel - unless your bike's manual specifies that the engine will give maximum performance on super unleaded, there is no benefit to filling up with super unleaded before your visit. We tune to standard 95RON fuel as it's commonly avialble. That doesn't mean you shouldn't use super unleaded where possible, as it often has other benefits such as better detergents and less ethanol than standard fuel, but you won't get more power with our tune from doing so."
Other engine tuners may have a different opinion.
AFAIK, octane rating is determined by the engine compression ratio and doesn't enhance performance. However, using a lower than specified octane ratio may cause pre-ignition/pinking. Modern bikes have anti-knock sensors, hence the Camhead and Hexhead being capable of running on lower octane fuel.
- Bike Model and Year: R1200RT/2006
Re: Which fuel
2006 R1200RT 43,000 miles.
I loive in Ca and I can tell you the stuff called Cheveron 91 barely works. The bike has a 12:1 compression ratio. Even with the dual plugs there is detonation. Gutless off the line. The stuff I use is by VP racing, 3.2oz : 1GL raises the octane to 98-99 range. Go ahead and run pump gas and then put some VP Octanium in what ever dilution you prefer. Much less knocking and a definitive change in your ingnition timing curve. It's as if a switch were thrown shut. Gone is the knock, and more robust the torque curve. Revs higher and comes up to rpm faster meaning more torque. Much more torque.
Granted the bike is not a sports bike and the max RPM is only 7000? Too many trips to redline and your adjusting your valves. But when the clutch engages around 3000rs the bike pulls as intended. Octainum works wonders only on injected bikeds with knock sensors. The reason you don't feel any difference with 87 and 98 is I don't know. I do. It's a performance machine, I treat it and ride it as such.
- Has liked: 637 times
- Been liked: 109 times
Re: Which fuel
I only use higher octane fuel because I don’t use my bike over winter so less ethanol is better I’d assumed just sitting in the tank. I’d planned on using 95ron for the summer but due to health reasons I really don’t know if I’m suddenly not going to be able to use the bike for a while. I’ll stick with 98ron for now.
- Has liked: 17 times
- Been liked: 138 times
Re: Which fuel
I've used premium grade & standard graded fuels in both bikes & cars, petrols & diesels and frankly I’ve never noticed any difference. I’m sure the science behind the manufacturers claims is sound, but to me the seat of the pants feeling is no different and my memory doesn’t recall me waxing lyrically to anyone about the great improvement in mpg I suddenly got.
No, I’ll keep the extra cash it costs in my pocket and use the regular stuff thank you.
- Steve398
Re: Which fuel
I do one posh fill up to every three paupers one! I read somewhere that that’s the way to achieve the best of both worlds.
- Has liked: 1465 times
- Been liked: 415 times
Re: Which fuel
Am a tightwad. The cheaper the better.
