I've just bought a new version which is the same as some of my friends intercoms, so this one is no longer needed.
One of the units has been playing up lately, so I want to be transparent and say there are two sets of everything, including unused helmet mikes and mounting brackets along with pads and Velcro also never used, but one of the units has an intermittent fault. I'm not sure how easy a fix this is, or if you just want the one perfectly working intercom and have the rest of the others set as spares, but I'm highlighting that one unit cuts out sometimes, other times it's fine, but I don't know the problem.
The battery life is still good, you will get the whole day from a charge, and all the functions are working perfectly other than one unit cutting out intermittently, which can be re set by turning it off and on again.
This is the set with the MESH function to connect to other riders as well as Bluetooth, it also does music, sat nav, phone and all the other stuff, too much to go through, so some bumf below:
Up to 15 rider multi-intercom simultaneously
Fully waterproof construction ideal for tours
Music and radio sharing ideal for large groups
Built-in FM radio with 6 pre-set stations
Compatible with Cardo Connect App
DMC intercom range of up to 1.6km / 1 miles
Intercom range can be extended up to 8.0km / 5 miles
Range extended when between a minimum of 6 riders
Automatic volume control for ease of use
Powerful 40mm JBL designed speakers
Status announcements, such as battery warning
850mAh battery with a talk-time of 13 hours
Takes roughly 4 hours to fully charge-up
Two audio channels for mobile and GPS
Universal Bluetooth 4.1 connection
Headset, hands-free and music profiles
Dimensions: 49mm x 91mm x 25mm
Speaker thickness: 9.2mm
Weighs approximately 57g
Looking for £150 (UK only please.)
