I have a RT1200 LE WC 2015, does anyone know if there is enough clearance behind the front wheel to fit a avant fender extender and a Mark Hooton crud catcher ? The quality is first class and it would stop the shotblasting of the engine casing.
ta in advance be
Shinyface
crud catcher
- Been liked: 334 times
Re: crud catcher
I knew I'd seen a picture somewhere, thanks to Mr Pope.
http://www.1200rt.com/index.php/topic,9 ... ml#msg6212
Re: crud catcher
Just remember behind the front engine cover is a multi plate wet clutch. Covering that up means a much reduced air flow so much less cooling. . I reckon a fender extender is a safer bet.
Re: crud catcher
Thanks for the input RT man, I`ve been considering that point too.......
Shinyface
Shinyface
Re: crud catcher
7000+ miles so far with the Crud catcher fitted. 2000 miles of that in France last year at 28c.
No problems at all so far with my RT's clutch.
Re: crud catcher
Thanks Pope that sort of makes up mi mind.....................I`ve spoken to a few with no problems either.
Shinyface
Shinyface
Re: crud catcher
Added the Fenda Extenda this weekend.
Not gone for the Crud Catcher yet - will see what difference the FE makes first...
