Hi all complete newbie here just got my first ever BMW an 06 1200RT I have been given a Givi topbox as there are only panniers on the bike the topbox is the monolock type so only comes with the one size fit all adaptor plate. Has anyone had any success fitting one or should i shell out for a different topbox ?
Monolock Topbox
- Been liked: 333 times
Re: Monolock Topbox
Givi do a specific adaptor plate for an R 1200 RT (05 >13), had one on a 2007 model.
http://media.givi.it/XN-Prodotti/istruzioni/E193.pdf
Re: Monolock Topbox
Thanks I checked it out and it's for the Givi Monokey type top box unfortunately this adaptor plate doesn't fit to the to box I have think I may be spending!!
Re: Monolock Topbox
Could the RT specific Monokey plate be switched for the one size fits all Monolock one, the grid looks very similar.
Re: Monolock Topbox
Excellent idea thank you ... I will get hold of the citing kit for the RT and try to swap the plates when fitting it thanks again
Re: Monolock Topbox
It might be worth offering up the Monolock Plate onto the RT Carrier, as the Plates (items 1 & 2), which the Screws go into are fixed in the 4 holes on the Carrier.
This image shows the Monokey Plate fitted, looking at the spacing of the bolts, the Monolock Plate may be too small.
