They’re a bit clumpy to start with Martin, but a seriously quality boot which will become more flexible with use. After 20-odd years they’ll be as comfy as your carpet slippers!Panman40 wrote: Thu Mar 20, 2025 3:27 pm Managed to get out for an hour today, the new ( used) boots are a bit disappointing, a little tight around the ankles but very hard to change gear getting them to bend to get my toes under and over the lever, do these Daytona boots loosen up at all ?, also no real feel for the lever either and noticed how much heavier they are compared to my ancient RST boots.
- Steve398
- Has liked: 584 times
- Been liked: 490 times
Thanks Steve, after 20 odd years I don’t think I’ll be needing bootsSteve398 wrote: Fri Mar 21, 2025 11:38 am They’re a bit clumpy to start with Martin, but a seriously quality boot which will become more flexible with use. After 20-odd years they’ll be as comfy as your carpet slippers!
- Ed Harley
- Has liked: 16 times
- Been liked: 106 times
Yesterday it was time to let Triumph go - sold it to the dealer I bought it from two years ago.
Lovely bike but I think I want another older and simpler bike. Perhaps an R1100GS or R1150GS from Germany.
Bono estente!
- EasyRider
- Has liked: 154 times
- Been liked: 414 times
Yesterday i replaced the rear tyre on my Varadero. I also removed the rear shock.
I got the haynes manual out and it told me to remove the fuel tank, rear ABS unit and a couple of other items.
I thought bugger that. I ended up making a bent 17mm & 14mm spanners so i could get to the top mount without have to take half the bike apart. I'm fitting a Hyperpro spring and 40mm lowering links. I'm trying to see if lowering the bike helps with the top heavy weight before i do sell it and get a Versys 1000. Its only cost £150 for the parts so i thought it was worth a try before spending ££££ on a lighter bike.
- Has liked: 1695 times
- Been liked: 549 times
What i did yesterday. I don't ride out on weekends as those working people seem to be on the road for some unknown reason.
I did what I like to do now and then. Set off with no destination in mind. The idea was only to use B roads. My first stop was at Winchester for a cuppa and a Bacon roll. I set off again along loads of twisties with 40 to 60mph limits passing through little villages that I never known before. Somehow I ended up in Poole Harbour. This time I needed a good hot meal. Luckily I found a Pub on the quay selling homemade meals. After a belly full of steak pie dinner I set off again. This time as time was getting late I decided it was the A27 all the way home. The Southampton section was a right pain. Speed restrictions are down to 40 mph for no reason at all. By the time I hit Chichester, It was again on B roads home.
Really nice day out. Next time i think it will be eastward.
- Glenn
- Has liked: 77 times
- Been liked: 258 times
Spent 7 hours today walking around the NEC at the Practical Classic Car and Restoration Show, I've walked around 6 miles in there.
- EasyRider
Today i thought it was time to tidy up the workshop.
I started at just before 7am and by midday it was in a bigger mess.
I did tidy it up, but then started going though what i had in boxes on the shelves.
3x1m shelves cleared, but big pile of rubbish now on the floor.
This is going to take longer than i thought.
- Has liked: 96 times
- Been liked: 141 times
I’ve been busy appeasing my OCD by labelling the new tool cabinet!
- IMG_6289.jpeg (263.95 KiB) Viewed 7285 times
- IMG_6288.jpeg (355.09 KiB) Viewed 7285 times
- Bike Model and Year: 2017
- Has liked: 330 times
- Been liked: 159 times
Soory but drill bits label is wonkey. in fact not happy with a lot of them.Sullivj wrote: Tue Mar 25, 2025 11:50 am I’ve been busy appeasing my OCD by labelling the new tool cabinet!
scunny12
- Has liked: 46 times
- Been liked: 57 times
Can you change the Wrench titles to English Spanner as well please.(unless its a torque wrench ,or monkey wrench. Its Vice grips too)
