Best oil for your bike
- Been liked: 476 times
Re: Best oil for your bike
How about this one from OPIE Oils, https://www.opieoils.co.uk/p-90213-motu ... e-oil.aspx it exceeds the BMW spec. for a Camhead.
- Bike Model and Year: R1200RT LE 2018
- Has liked: 39 times
- Been liked: 20 times
Forgive my ignorance on oil specs, but how does one know if an oil spec is better or worse than the manufacturer recommended please? Thank you.David. wrote: ↑Sun Aug 25, 2024 8:21 am Looking at this video reminded me of the following. As per the BMW Rider's Manual, the engine oil spec. is API SF / ACEA A2, or better, with various viscosity ranges based on the ambient temperature. No mention of JASO MA or MA2 for wet clutches. The 2012 Camhead has a car like dry clutch. The BMW Motorrad ADVANTEC Pro oil spec. is SAE 15W-50, API SJ / JASO MA2. Why pay more for a wet clutch oil when it is not required. Has anyone used a car oil in their dry clutch RT.
The oil spec. for a Camhead is API SF / ACEA A2 or better.
The spec. of the Motul oil linked above is API SN / ACEA A3.
- Has liked: 7 times
- Been liked: 2 times
yeap. I use car oil. Shell Helix hx7 10w40 same as Shell Advance AX7 for bikes but without JASO MA2.David. wrote: ↑Sun Aug 25, 2024 8:21 am Looking at this video reminded me of the following. As per the BMW Rider's Manual, the engine oil spec. is API SF / ACEA A2, or better, with various viscosity ranges based on the ambient temperature. No mention of JASO MA or MA2 for wet clutches. The 2012 Camhead has a car like dry clutch. The BMW Motorrad ADVANTEC Pro oil spec. is SAE 15W-50, API SJ / JASO MA2. Why pay more for a wet clutch oil when it is not required. Has anyone used a car oil in their dry clutch RT.
it exceeds all requirements stated on my 2010 camhead user manual.
Castrol GPS SAE 10W-40, API SG / JASO MA ~-20 °C
SAE 5W-40, API SF / ACEA A2, ou superior ~-20 °C
SAE 5W-~50, API SF / ACEA A2, ou superior ~-20 °C
SAE 10W-40, API SF / ACEA A2, ou superior ~-10 °C
SAE 10W-~50, API SF / ACEA A2, ou superior ~-20 °C
SAE 15W-~40, API SF / ACEA A2, ou superior ~0 °C
- Bike Model and Year: R1200RT 2006
- Has liked: 2 times
- Been liked: 3 times
I use this brand in the car.
https://moto.autodoc.co.uk/mannol/15768226
Never had an issue. Is it good enough for an R1200RT 2006?
