Two day owner grumbles and gripes
- Bike Model and Year: R1200RT LE 2018
- Has liked: 39 times
- Been liked: 20 times
Re: Two day owner grumbles and gripes
“Live from Lancashire”, broadcasting to a forum near you with an A&Q
- jesim1
- Has liked: 142 times
- Been liked: 85 times
My alarm sets automatically, it's in the set up somewhere, but it's the kind of thing you set and forget except when going on a ferry
I ride in ROAD if just pottering about, but mostly ride in DYNAMIC, not for any speed advantage, I just feel the response is better and my fat ass likes firmer suspension, although you can go into the menus and separate the suspension from the engine if you want to tune those further.
I put a "tail" terminal on the battery and secured it behind the right side quarter panel, it's easy to get to and I can plug both my compressor and Optimate into it as I bought the appropriate connections for them, just makes life easier
Reminds me. Puncture kit. Been way too long without one…. Thank you.
I need to have a run and try the different modes. Road gives “norm” for suspension. Dynamic gives “hard”. It is my intention to change one thing at a time. Detaching suspension from rider mode would probably be where I’ll end up (or put the preferred suspension to all modes). On my old Tiger and Speedie I used to switch modes depending on traffic, although they never had electronic suspension adjustment.
- Has liked: 1433 times
- Been liked: 406 times
My rear crash bars have saved my panniers a couple of times. I wouldn't be without them.
Why so much. I've replaced mine on TomTom and Garmin. Batteries cost less then £5 and that was with upgraded batterieslancashirert wrote: ↑Sat Aug 31, 2024 4:42 pm BMW - Bring More Wedge!
Like the Nav V/VI battery. £70 from BMW, £13 from Garmin.
Because they can, and we're in post-Covid inflation? Still, £13 to make a freebie work isn't a complaining matter!
- Has liked: 17 times
- Been liked: 134 times
Ref Quickshifters. You have to remember quickshiters originated from the track and were designed for revvy engines. Move that technology to a lower revving engine designed to produce loads of low end grunt and it just doesn't work so well. That's not to say the QS doesn't works, just to make it work properly you have to be at, shall we say 'making progress' speeds and then onlt in the top few gears. Lower down the box and at lower speed it's using the clutch is just smoother. You can make it work at lower revs, sort of, but it ain't what it desgined for.
Indeed, figuring that out as I go. The box isn't too bad really, but Triumph's box on the 675 engines is really nice, so you notice anything less even moreso. And also remembering that this bike has way more engine braking than most bikes I have ridden!Capt Sisko wrote: ↑Tue Sep 03, 2024 11:09 am Ref Quickshifters. You have to remember quickshiters originated from the track and were designed for revvy engines. Move that technology to a lower revving engine designed to produce loads of low end grunt and it just doesn't work so well. That's not to say the QS doesn't works, just to make it work properly you have to be at, shall we say 'making progress' speeds and then onlt in the top few gears. Lower down the box and at lower speed it's using the clutch is just smoother. You can make it work at lower revs, sort of, but it ain't what it desgined for.
- Bike Model and Year: BMW R1200RT 2015
- Has liked: 46 times
- Been liked: 11 times
Phone Mount note here: I bought the "flea-bay" induction Nav-mounted holder, and it hasn't skipped a beat in 7,000km over my few months of ownership. I use google maps, blue-tooth to headset, GPS logger and sometimes play music, and it still provides enough power to charge the phone while riding. The spring feels a bit too strong, but my phone is still alive (Samsung 10e). It has power, there are no cables and it does not look as a third-party addition when left on the bike.
The location is perfect and after having phone previously off-centre, I do prefer it mounted centrally now. It does not distract anything, and is easy to glance at (for city directions).
For less than €40 delivered within two weeks, I'd keep the RAM mount for other accessories (e.g. cup holder) and use the powered (and wireless) nav-mount adapter.
I am here to learn.
Thanks for that!
Wasn't aware there was a cup holder for RAM mounts!
Spill-proof cup holder - https://rammount.com/products/ram-b-132bu. I have a search saved for it on fleabay. Our second office is 2 hours away, which would make for perfect time to sip my morning brew.
I am here to learn.
Finally got a wee solo blast. Nothing too exuberant due to urban and suburban speed limits.
Need to wrap my Abus disc lock in a cloth cos I can hear it tinkling.
Need to ride without panniers (had to as I was picking up something) to see if it’s quieter over rough bits, if not that’s gonna be a an annoying thing to track down.
Bit skippy of a rough exit to a mini roundabout, didn’t feel alarming however.
Now to work out where I actually like the screen. Don’t get the clean air flow like you do on a naked bike.
All stacking up nicely!
