1250RT Comfort Turn Indicator Setting resets itself
Jggpossum
Has liked: 3 times
Been liked: 21 times
Australia
Re: 1250RT Comfort Turn Indicator Setting resets itself
Post by Jggpossum »
There are some serious bugs in this software so I hope any release does a proper job. My dealer was told by BMW that they didn’t expect a release before March and I think that was a sign of the depth of concern they had about how bad the software had become.
RaP
Bike Model and Year: R1250RT MY2023
Germany
Post by RaP »
Turns out that it was a complete waste of time. I assume the workshop guys are bored during winter time and to raise their utilization they spent some warranty cash to play around with my bike. No update only another try to get the existing version to work. No surprise that the indicator setting was already inactive by when I took my bike. 🤦‍♂️
danielgc1981
Spain
Post by danielgc1981 »
Hello All,
I hava a 2022 R1250RT and this summer had the typical Emergency call issue. They restore all the software and since then I have the comfort turn indicator issue.
In my case, I also notice that the ACC recover type (comfort or dynamic) also restores automatically to comfort like the turn indicator.
Hope it will be solved with new update so I can call the dealer and set an appointment.
Jggpossum
Has liked: 3 times
Australia
Post by Jggpossum »
I am getting used to this now and am sceptical that BMW have the capability to write reliable software - at least for the RT. My routine now before starting is
1 turn comfort indicator on
2 reset trip computer.
3 set TFT to split screen then the tricky process of getting maps up using connected ride. At least that works pretty reliably now.
The bugs get worse with each update. I think there are a raft of system issues coming from this latest bug.
1 comfort Turn resets after a few idle hours.
2 trip computer doesn’t reset when set to auto reset
3 trip computer if set to auto reset will randomly reset to zero Km part way through a ride while in motion
4 mode Dynamic Comfort reset on some bikes
5 Radio reset (don’t use it so can’t confirm)
6 TFT returns to full screen if set to split. Happens at same time as comfort turn reset.
7 Menu position defaults back to first menu position when these resets occur. Normal behaviour is to remember and stay on the top menu last used. Eg Nav or System etc
Any others?
acftfliehr
Post by acftfliehr »
This is interesting... I had set this up and went to the dealer to ask why it's not working, we went into the settings and it was not checked! Thought it was but the logic is misleading and I thought I had set it up earlier properly?!? Now I know I'm going bloody psycho mad! Haw. I've been riding a 1985 K100RT since new with over 300K miles on the clock. It's Auto cancel turn signals were brilliant! See what the owners manual says... I've petitioned BMW to consider this as an option since they are rewriting the SW. I think they use the on board AHRS sensor that senses lean angle to do this function, a lot more complicated than what they had that worked brilliantly a long time ago!!
About 15 years ago, a very experienced airhead rider got into a pretty good accident when someone pulled out in front of him after he was absorbed in riding and forgot to cancel. He said after that he just didn't use them anymore. I don't agree, but maybe if I had survived after something like that, I may agree as well on that :fix".
In my opinion, this is should be a safety recall given how worried BMW about safety. this is a safety critical item in my opinion. It should work as the manual states....
My bike 2024 R1250RT - Purchased in late Sept 2024...
1985 K100 manual no software upgrade for this and it works since 1985....
"The left or right turn indicators are cancelled automatically after a certain time or distance if this is not done by pressing
the switch :
@ after approximately 10 seconds at main road speeds — above approximately 30
miles per hour or 50 km/h, or
@ after approximately 210 m (690 ft) in
local or slow-moving traffic.
stuartg1969
Bike Model and Year: rt1250 2024
Post by stuartg1969 »
I brought a 2024 model and have just noticed that this keeps resetting itself
RaP
Germany
Post by RaP »
stuartg1969 wrote: Mon Mar 10, 2025 9:34 am I brought a 2024 model and have just noticed that this keeps resetting itself
You are welcome to the club! See it as a good training for the other Nonsense BMW programmed into the Bike. Navigation connection losses will make you forget about the issue and while your seat heater is fighting freezing temps (not winning though) you will switch permanently between wobbly soft and steel-hard suspension setting searching for answers why they did not implemented a perfect middle setting. 😉
acftfliehr
It appears that the Bikes Navigation system code is probably written by a car division engineering team in Stuttgart, and the Motorrad App software written in Berlin - With the 2 teams arguing on how the system should be synergized. The blame is at the poor expediters trying to appease the 2 parties.... So goes it for the Improperly labeled "Comfort Turn Signals". Each time I fire up the bike, its the first thing in my start up checklist.. Most of the time it's deselected but about 20% of the time it's still checked?!?
This reminds me of the front fork engineer for the initial K100 statement was when asked back in the early 80's - "Why did not the forks have adjustable anti-dive, dampening rebound options as well as a fork brace like all of their competitor's?
His response.... "Because they were designed "Perfectly"".... Haw... Probably the 2 Engineering teams are both saying their side of the fence is perfect as well and we are all simply stark mad?!?
Has liked: 1464 times
acftfliehr wrote: Mon Mar 10, 2025 4:24 pm
Sounds like Henning Vain
Why do they call them Comfort Turn Indicator? Nothing is comforting about them. They don't jump up and give you a massage to your neck Ot rub your bum. They are just automatic indicators. I think something got lost in translation.
Been liked: 415 times
Doctor T wrote: Tue Mar 11, 2025 1:12 pm Why do they call them Re: Comfort Turn Indicator? Nothing is comforting about them. They don't jump up and give you a massage to your neck Ot rub your bum. They are just automatic indicators. I think something got lost in translation.
It's because they don't chaf the delicate fingers of the BMW rider :thumb:
stuartg1969
Hi All, anyone had any further updates on this?
RaP
Germany
Post by RaP »
Yep, I have tmr a date for an update which should exactly address the issues with the overnight lost settings.
Ah, btw. the Software Version is according to my dealer 25-03-500
That seems a little odd and is not in any sequence with the former Versioning but that's what I was told. Let's see.
RaP
Germany
Post by RaP »
RaP wrote: Tue Mar 25, 2025 4:20 pm Yep, I have tmr a date for an update which should exactly address the issues with the overnight lost settings.
Update on my Post I've got the Update. The mentioned Version 25-03-500 is the new Vehicle Main Software and was before 24-11-500 .
The user-displayed Software Version is now 014_015_020 and they said, that this will solve the issue. Let's wait a night, I keep you posted.
acftfliehr
Had my first service yesterday, they updated (I don’t know what version yet) but this am it was still ticked! I’m not a trusting one so I’m going to be checking the tick until it stays on for at least a week…. Maybe a month.. or year?!?
