Fuel reserve
Re: Fuel reserve
Us LC owners are spared such dramas as the fuel sensor has reverted to the Victorian style toilet float system.
Re: Fuel reserve
Ballcocks ! ;DRTman10 wrote:Us LC owners are spared such dramas as the fuel sensor has reverted to the Victorian style toilet float system.
Re: Fuel reserve
DaygloDavid wrote: Did the bike restart easily after adding the fuel from the can.
Yes, I ran the bike out of fuel twice last night and both times it started after about three revolutions and settled to a steady idle. (Tonight's experiment has been postponed ti'll tomorrow).
- Been liked: 477 times
Re: Fuel reserve
If you're worried about running out of fuel, could always fit one of these, https://www.youtube.com/watch?v=Hg_xmMR5Kbg
This looks like where the gravity feed auxiliary fuel tank connects to the standard fuel tank.
Re: Fuel reserve
Went to Scotland on a VFR800, the others two lads were on a GSXR750 & a VFR400, more for their sake than my own, I took a 5 litre fuel can in a tail pack attached to the pillion seat.
- Has liked: 80 times
- Been liked: 87 times
Re: Fuel reserve
Givi make a 2.5l can. When France had their fuel strikes, I took one when we went touring.
Apparently, the ferry company don't allow you to take containerised fuel. Thankfully, they didn't spot it buried in my top box.
Re: Fuel reserve
When I do the route planning - I go for 300km before planning a fuel stop. This way, I estimate I have about 100km before I get to"Oh dear I have to start pushing"
So far - I have never run out of petrol, and I get to choose where I fill up & what the price is!
Best regards, Sleuth
Re: Fuel reserve
The one variable I wonder about when determining how much fuel the tank took vs documented capacity, is how full the individual actually considers full. The collar inside the fill cap stops fueling well before the tank is full. I have found it takes a bit of patience to actually fill my tank to capacity with the vapor recovery nozzles.
Ain't nothin like a friend who can tell you you're just pissin in the wind - Neil Young
Re: Fuel reserve
I brim mine by withdrawing the fuel pump filler nozzle as the fuel level rises up the filler neck.
Re: Fuel reserve
Me too David. wrote: I brim mine by withdrawing the fuel pump filler nozzle as the fuel level rises up the filler neck.
Re: Fuel reserve
I used to go through the process of seeing just how far up the neck I could get the fuel but I got tired of wiping the fuel splashes off the tank afterwards. Now I just fill until I can see fuel at the bottom of the filler neck and then I stop. Much less mess and I doubt the cup-full of fuel that would sit in the neck makes that much difference.
I'm getting around 300 miles from a tank as it is so I have no complaints whatsoever (especially when comparing with my GS which struggled to make 240 miles on a tank).
Re: Fuel reserve
This guy with a 2008 K1200S decided to "butcher" the fuel tank filler neck to improve venting whilst filling the tank, http://www.i-bmw.com/showthread.php?t=28824
Have found, that with care & patience, the tank can be brimmed without problems. Any small overflow will go down the vent hole in the annulus around the filler neck.
Re: Fuel reserve
The LC tank seems to fill easier near the end than I can remember on earlier bikes.
Re: Fuel reserve
Why, what's the difference between the LC & earlier bikes.RTman10 wrote:The LC tank seems to fill easier near the end than I can remember on earlier bikes.
Benchmark has an LC & I have a TC, both can be brimmed without any problems.
