Page 1 of 1
Light recommendation?
Posted: Fri Sep 11, 2015 3:12 am
by mercator1
Tomorrow all the accessories for my new RT should get delivered (VStream, Wunderlich bars, Ilium highway pegs, sport boards and bar back, fender extension and stubby antenna).  The only main things I'll have left have to do with visibility.  I'm leaning towards the Denali DM Micro driving lights, since I like the small footprint.  I think they'll mount on the forks nicely.
Anyone have experience with them?  I'd also like recommendations for LED tail lights.  My brother was following me, and really thought the visibility from the rear was lacking.
Re: Light recommendation?
Posted: Fri Sep 11, 2015 7:48 am
by guest3074
mercator1 wrote: I'd also like recommendations for LED tail lights.  My brother was following me, and really thought the visibility from the rear was lacking.
/index.php/topic,1578.0.html
I used the Skene P3 which been american you should be able to get easily, if you look on their website they give detailed wiring instructions on how to fit but for the ground and brake light trigger I connected into the spare wiring for the topbox as I don't have the central locking option etc fitted to mine.
http://www.lights.skenedesign.com/
http://www.lights.skenedesign.com/R1200RT.shtml
Posted: Sat Sep 12, 2015 4:03 pm
by T6pilot
P3 lights are the best, done over a dozen installs, all riders have been satisfied with results
RT install simple just follow Jerrys instructions
Posted: Sat Sep 12, 2015 4:35 pm
by mercator1
Yeah, the Skene is what I had been looking at. They certainly don't go to any great effort to make them attractive, but I guess it's the functionality that really matters.  Do any of you that ride with other guys hear complaints when they are following for a long distance?  Looks like that conspicuity flicker would get annoying if you had it in front of you for a couple of hours on a ride.
Posted: Sat Sep 12, 2015 7:07 pm
by T6pilot
During the programming of P3 lights, flicker can be disabled, I've done that on all my installs
Only reason I have done so many bikes is my buddies that ride behind me, realize the safety value of aux lights
Yes P3's are all about function and not beauty
Posted: Sat Sep 12, 2015 8:35 pm
by Ch00
I have those each side of my number plate (after a bit of adjustment)
I have the glint mode on but have turned the brake flash off.
Posted: Sat Sep 12, 2015 9:03 pm
by guest3074
Ch00 wrote: I have those each side of my number plate (after a bit of adjustment)
That's where I had them on my 2010 RT and I had both those modes turned off  ;)
Posted: Sat Sep 12, 2015 9:17 pm
by mercator1
Thanks for the info. The 4 fast and 4 slow followed by solid seems like a nice feature. I assume the various modes are fairly easy to cycle through, no?
Posted: Sat Sep 12, 2015 9:22 pm
by Ch00
When you turn the ignition on you have a few seconds to change the settings on the brake light. Just squeeze the brake lever the right number of times.
Posted: Sat Sep 12, 2015 9:38 pm
by T6pilot
I've found programming to be easier, by using the 14 and up RT method. Turn ingition on and using a jumper from battery touch brake wire to hot lead the correct number of times to program what you desire
