Which is the best oil for the final drive on 1200 rt
adewhitmarsh
Post by adewhitmarsh »
Which oil are owners using in the final drive ??
Been liked: 348 times
Re: Which is the best oil for the final drive on 1200 rt
For my 2012 TC, I use, Castrol Syntrax Longlife 75w-90.
Levisp
Post by Levisp »
+1 agree. Castrol Syntrax Longline 75W-90 is the recommended oil for 2014 RT LC bikes.
On my 2007 RT, (same as 2005),I seem to remember Castrol SAF-XO was used in the Final Drive.
Castrol have replaced SAF-XO with Syntrax Long Life 75W-90, http://www.castrol.com/en_nz/new-zealan ... 5w-90.html,
therefore all the 3 RT Models now used the same Final Drive oil.
I use whatever the dealer puts in it!
To steal a line from Edmund Blackadder, "I'm one of those people quite happy to wear cotton but I have absolutely no idea how it works"...
YEP And now its all branded BMW made by Shell
Does the Dealer charge for the amount of oil used, (e.g. 180 ml in a TC),  or for 1 litre which would be the Unit Price.
Levisp
Post by Levisp »
When the dealer did mine at the free run in service ( 600 + miles ) they overfilled it ! Put in 200 ml One reason why I do my own. Second reason it cost me £3 to change the oil and 10 mins of my time. Bet you BMW charge a lot more than £3 !!
One of the gripes I had with Cooper Sunderland was,
on the 2007 RT, they changed the final drive oil at 600 miles and charged me for 1 litre of oil at around £27 per litre.
On the 2010 RT, Barrie Robson (York),charged for 0.2 litre (£6.63),the cost per litre was £33.12.
Just changed the Final Drive oil on my 2012 TC this morning, at a cost of £2.50 for the oil used.
Have ordered a Syringe to make life easier next time, it was a bit of a slow process with a small funnel & some air line tubing, especially on a cold day.
http://www.amazon.co.uk/dp/B013QO8MKQ/r ... item_image
RTman10 wrote:Now its all branded BMW made by Shell
This looks like the BMW stuff, http://www.ascycles.com/detail.aspx?ID=123778, for use in all 2005-later BMW shaft drive bikes.
This is how you do it on the first 1200 RT's which don't have a drain plug.
Perhaps why on my 2007 RT, the oil was changed at 600 miles, then in for life.
Levisp
Post by Levisp »
Thats hilarious. Its a joke right ? You are meant to take the back wheel out, undo the torque arm bolt and swivel the final drive to drain the oil. Good thing someone at BMW had the bright idea of installing a drain bolt on the later bikes. ???
Steve F
Post by Steve F »
:)) No way. This is a set-up. Mind you, it would make for a great caption competition...!!
Levisp wrote:That's hilarious. You are meant to take the back wheel out, undo the torque arm bolt and swivel the final drive to drain the oil.
Just had to post & share it, made me laugh too.
As you say, this is the correct way to do it, http://www.jvbproductions.com/R1200_Final_Drive.html.
T6pilot
Post by T6pilot »
MOTUL 300
Sae 75/90
100% syntheses ester base
API GL4/5 Mil-l-2105d
$25 per liter
Came highly recommended by independent shop
