Sat Nav socket 2006 R1200RT
Just bought the linking cable for sat nav, but I don't seem to be able to locate the factory fitted socket on the wiring loom. CXan it be located without the removal of body panels? Any tips will be appreciated. Thanks.
Re: Sat Nav socket 2006 R1200RT
Underneath the headlight you will find a black bracket running forward from the headstock frame. The cable is normally cable tied to that. The socket is white but might have a black dust cover on it.
- Been liked: 323 times
Does this look like the power supply cable.
If so, the socket on the Bike (2012 Model), not sure if it's the same for 2006, is located below the headlight assembly, as per these photos.
