Yup, I have. Same pair been on my last two RT's. I obtained them from a chap in Canada about 6 years ago when I fitted the larger version of the Z Technik Screen.adewhitmarsh wrote: I have heard that the two screen support brackets can snap,is this due to fitting larger screens ?? I saw on a Web site you can replace them with stainless steel brackets.any boy fitted them ??
Stripped threads on the screen mounting rails
- Been liked: 17 times
Re: Stripped threads on the screen mounting rails
- Been liked: 322 times
Having tried a couple of Cee Baileys Windshields on both my 2007 & 2010 RT's, one problem I found was that sometimes the Actuator (motor) wouldn't drive the screen up & down when travelling at certain speeds.
My concern was causing damage to the Actuator (electrically overloading it) & support brackets, therefore "ditched" the idea & reverted back to the stock screen.
Surely BMW R&D plus Wind Tunnel testing of aerodynamics etc. would come up with the ideal solution.
Decided that if I wanted to be cosseted behind a windscreen, I'd take the car.
You would've thought so, wouldn't you...!! ??? Obviously not so for two wheels...four wheels maybe!DaygloDavid wrote: Surely BMW R&D plus Wind Tunnel testing of aerodynamics etc. would come up with the ideal solution.
Perhaps they do, but not very well,DaygloDavid wrote:Surely BMW R&D plus Wind Tunnel testing of aerodynamics etc. would come up with the ideal solution.
https://www.press.bmwgroup.com/global/p ... =P90059274
Well, my Z Technik screen, the larger version, has been fitted to both my RT,s and I have never had a problem raising or lowering the screen whilst riding. That said, common sense tells me not to attempt operating it at "certain speeds".DaygloDavid wrote: Having tried a couple of Cee Baileys Windshields on both my 2007 & 2010 RT's, one problem I found was that sometimes the Actuator (motor) wouldn't drive the screen up & down when travelling at certain speeds.
BMW R and D plus wind tunnel testing probably did come up with the ideal solution but no doubt the chaps in the "Does it look Cool" department gave it the thumbs down and settled for the Neat and Cool but not very effective appearance of the stock screen.
As far as being "cosseted" behind my Z Tech, well I just love it and if I do want to feel the blast of nature I can always lower the setting. At a sensible speed of course !!.
Still, we are all different, so each to his own.
