engine guards
turdboman
Re: engine guards
Post by turdboman »
i found this ,list shows rt
turdboman
Re: engine guards
Post by turdboman »
found this ,it lists 2016 rt
turdboman
Re: engine guards
Post by turdboman »
[attachimg=1]found this ,it lists 2016 rt
turdboman
Re: engine guards
Post by turdboman »
I liked the wunderlich but i saw someone who dropped the bike and the put on illium ,i tried to ask him why but no reply !! if you like them i'll have a look . how about touratech they look good but the bolt on the head , it seems they would transfer the impact right to the engine !!
Re: engine guards
Spencert231 wrote: Why specifically OEM engine bars? There are good engine bars out there no different to how BMW would contract a company to manufacture for them. I got mine from Wunderlich and I'm very pleased with them.
I suspect they believe the same as me.  If the bars are well out from the heads and a bit higher there is a danger that in a drop the bike will pivot more.  This can happen on the 1600 where the bar is there to protect the engine.  The result is more damage than is necessary to the upper panel parts and mirrors and the top panel of the panniers than would normally happen. I know of LCs that have been dropped on level ground with the OEM head protectors fitted and nothing else has touched down.
Re: engine guards
turdboman wrote: [attachimg=1]found this ,it lists 2016 rt
Don't care what the site says.  These won't fit the RT without you butchering the lower panels.  And then the top fixings probably won't fit either
Been liked: 480 times
Re: engine guards
Putting Part No. 77148533693 into RealOEM comes up with, K52 (R 1200 RT) R 1200 RT (0A03, 0A13) Set, cylinder-head cover guard.
http://www.realoem.com/bmw/enUS/partgrp ... g=77&sg=14
Putting the Part No. into a "Google Search" comes up with, ENGINE PROTECTION BAR SET, not listed for the RT.
http://parts.bmwmotorcycles.com/p/BMW__ ... 33693.html
Looks like the Fitment/Applications refers to both Assemblies, i.e. Engine Protection Bars & Cylinder-Head Cover Guards.
Re: engine guards
RT with Cylinder-Head Cover Guards fitted, (note lower fairing panel).
GS with Engine Protection Bar Set.
turdboman
Re: engine guards
Post by turdboman »
Ok ,I bow to your knowledge .On the other hand I do have 81 miles on my bike so I may be the new guru !! Thanks for your help and concern ,all of you !! Happy Trails to you all .
turdboman
Re: engine guards
Post by turdboman »
Well i talked to the parts person at my dealership and after several hours wait she called me back and informed me that BMW does not make protection bars for the 2016 R1200RT yet !! so thanks and now wunderlich or ilium ?
Re: engine guards
Why not use what BMW provide.  They work and are not attached to parts of the bike not designed to take the shock of a drop. You also don't end up looking like somebody delivering scaffolding.
Re: engine guards
turdboman wrote:BMW does not make protection bars for the 2016 R1200RT yet !! so thanks and now wunderlich or ilium ?
Wunderlich, https://www.youtube.com/watch?v=9GOrJ8vTJHI
Ilium Works, https://www.youtube.com/watch?v=TFsU3yCUt7g
turdboman
Re: engine guards
Post by turdboman »
RTman10 what parts that BMW provided are you referring to ? I can't figure out how reply correctly !!
Re: engine guards
DaygloDavid posted to very clear pictures here. The first one showes the proper engine protection .
Re: engine guards
With these ZTechnik Engine Bars, the front lower mounting point is bolted directly to the Engine, https://www.youtube.com/watch?v=8QRTQ2rEZCI
