chrismckay
Posts: 89 Joined: Sun Jul 27, 2014 8:32 am
Post
by chrismckay » Sun Jan 31, 2016 7:37 am
Anyone know where I can buy spare safety pins for the front brake pad retainer pins?
Chris...
Post
by guest2360 » Sun Jan 31, 2016 8:01 am
BMW Part No 34 11 7 660 850. Mounting Parts Set. Includes the pin, spring and clip.
chrismckay
Post
by chrismckay » Sun Jan 31, 2016 8:56 am
Cheers RT,
Just need the clip though!!!!
Post
by guest2360 » Sun Jan 31, 2016 8:59 am
They are not available by themselves. The whole lot costs not a lot.
Posts: 7944 Joined: Fri Nov 07, 2014 7:29 pm
Been liked: 322 times
Post
by David. » Sun Jan 31, 2016 10:11 am
Motorworks,
https://www.motorworks.co.uk/vlive/Shop ... 0&spPage=3
Would a simple R Spring Clip like the one for the Tokico caliper do the same job for a fraction of the cost,
https://www.motorworks.co.uk/vlive/Shop ... 0&spPage=2
The closed P end of the correct diameter D might do the trick. The open end could be bent through 90 deg. or cut short to ensure it doesn't foul any part of the caliper or pads.
The wire diameter d would need to be the same as the original clip to fit into the Caliper Pin groove.
If necessary, the R Spring Clip could be slipped over the end of the Caliper Pin as it's being installed.
Bike Torque Racing may be able to help,
http://www.biketorqueracing.co.uk/sole-uk-distributor
David. on Sun Jan 31, 2016 1:08 pm, edited 1 time in total.
chrismckay
Post
by chrismckay » Sun Jan 31, 2016 6:22 pm
Thanks again Dave, I have mailed the guys at Bike Torque Racing....
Post
by guest2360 » Sun Jan 31, 2016 6:58 pm
I would strongly advise to only fit OEM brake parts. The set that includes the pin from a BMW dealer I think cost about £10.00. Not worth trying to save a few quid with brakes.
Post
by David. » Mon Feb 01, 2016 9:56 am
Pinstructure have provided a pdf. document with details of their range of Retaining Pins.
(Left click on the photo, then click the box with the arrow in the top righthand corner to expand to actual size.)
David. on Mon Feb 01, 2016 10:11 am, edited 1 time in total.
