mounting with a top case
Re: mounting with a top case
Not trying to make fun, just trying to understand your problem .
RTman10 wrote: And no the stand will not buckle or snap.
In the summer it might dig into the soft tarmac though - same for gravel in car park...
Vince Prince
Post by Vince Prince »
Good advice. After having my Aprilia sink into my mates tarmac drive, I never go anywhere without a puck... the twenty-first century replacement for a squashed coke can.
Been liked: 19 times
And a great mod to the puck is to drill a small hole in it and attach some string. You can then sit on the bike and pull the puck out, stick in your pocket and off you go  :)
mercator1
Post by mercator1 »
turdboman wrote: Any techniques for mounting with a top case  , i can't lift leg high enough to just put it over seat !
  With my top case on (new model not as simple to remove), I have trouble lifting leg over seat to mount.  My knees are bad, and it's a stuggle. However, I just bend the knee up as much as I can and grab the pant hem with my right hand and help it over.  Works ok.  Getting off is easier.  I can do the reverse while hopping back a little on my left leg.  These bikes are made for short guys with bad joints.
Tango
Post by Tango »
turdboman
Post by turdboman »
mercator1 wrote:   With my top case on (new model not as simple to remove),I have trouble lifting leg over seat to mount.  My knees are bad, and it's a stuggle. However, I just bend the knee up as much as I can and grab the pant hem with my right hand and help it over.  Works ok.  Getting off is easier.  I can do the reverse while hopping back a little on my left leg.  These bikes are made for short guys with bad joints.
That's what i finally figured out ,grab my cuff and lift it over seat !!
