Page 1 of 1
Gap under the seat?
Posted: Sun Feb 28, 2016 7:42 pm
by Orso62
Hi, I am sure the topic has already been discussed so apologies in advance. Have put my heated regular seat on its high setting and have noticed that there is now a (narrow but disturbing) gap between the lower side edge of the seat and the bodywork. Thought I made a mistake in putting the seat back and tried to reinstall it twice to no avail. Is it me being thick and ham fisted or is it BMW's design a little flawed? Ciao! Massimo
Re: Gap under the seat?
Posted: Sun Feb 28, 2016 8:00 pm
by step2534
Orso62  What year is the bike??
Are you sure its a regular seat and not a low one??  If you put a low seat in the high setting it gives you a gap or at least it does on the pre watercooled machines
Posted: Sun Feb 28, 2016 8:10 pm
by Orso62
Hi, the bike is a RT LC just purchased as new. :)
Posted: Sun Feb 28, 2016 8:16 pm
by Orso62
Seat is regular [emoji4]
Posted: Sun Feb 28, 2016 9:51 pm
by David.
Orso62 wrote:Have put my heated regular seat on its high setting and have noticed that there is now a (narrow but disturbing) gap between the lower side edge of the seat and the bodywork.
Is this what the seat/bodywork looks like in the Low & High positions.
Posted: Sun Feb 28, 2016 9:56 pm
by David.
step2534 wrote:If you put a low seat in the high setting it gives you a gap or at least it does on the pre watercooled machines.
This is why I don't put the Standard Seat in the High position on my 2012 RT, it "looks a bit naff".
Posted: Sun Feb 28, 2016 10:04 pm
by Orso62
Yes. It looks like that. Thank you. Seat will go back to the low position but I must say that BMW could have designed it a little better!
Posted: Sun Feb 28, 2016 10:50 pm
by beemerboy9
Hi David,
I also think it looks "a bit naff". I was thinking of getting the high seat and putting in the low position. How did that work out for you?
Posted: Sun Feb 28, 2016 11:02 pm
by David.
beemerboy9 wrote:I was thinking of getting the high seat and putting in the low position. How did that work out for you?
Sorry for any confusion, a 2012 RT (which I have) has a Standard & Low Seat option only, whereas the LC has 3 options, High, Standard & Low.
Posted: Mon Feb 29, 2016 7:35 am
by guest2360
I don't see how, with the panel obviously always in the same position it would be possible not to see more of it if you raise the seat. There isn't really a gap just more of the insert showing. Quite a neat solution for a seat that allows you to put it in 3 different positions.
Posted: Mon Feb 29, 2016 7:41 am
by guest3074
RTman10 wrote: Quite a neat solution for a seat that allows you to put it in 3 different positions.
3 positions ? There's only 2 High and Low on mine  ;)
Posted: Mon Feb 29, 2016 7:58 am
by guest2360
Same frame different seats adds up to at least 3 if not more if you see what I mean.  Most bikes it's as it is.
Posted: Mon Feb 29, 2016 8:59 am
by David.
What Year is your Bike & which Seat do you currently have.
Posted: Tue Mar 01, 2016 4:31 am
by rglassma
I don't see what the problem is.  It is a functional adjustment.  It works.  Having versatility often requires trade offs.  Every time you think about it, get on the bike and twist the throttle.  I bet you will forget all about it in no time.
Sent from my SM-T310 using Tapatalk
