Tool bag essentials
- timminator
- Been liked: 2 times
Tool bag essentials
I'm curious how many of you carry an assortment of tools, tire repair kits, zip ties, hose clamps, or other essential goodies with you while riding? Since the bags should be balanced, where do you like to carry the tools so they don't impact your balance and also don't rattle around?
I have a very well-equipped garage, but have generally not bothered taking many tools with me. I'm thinking of equipping a small toolbox for those all-day rides.
Cheers, Tim
Cheers, Tim
BMW MOA #210438
- Been liked: 480 times
Re: Tool bag essentials
On a 2012 TC RT (non-Audio), there is sufficient space in the storage compartment (upper RHS fairing), under the pillion seat & behind/under the tail light unit for all tools, a puncture repair kit plus mini compressor etc.timminator wrote:I'm curious how many of you carry an assortment of tools, tire repair kits, zip ties, hose clamps, or other essential goodies with you while riding? Since the bags should be balanced, where do you like to carry the tools so they don't impact your balance and also don't rattle around?
Only ride with the bags (panniers) on when carrying luggage for touring.
Not so many cubby holes for bits on the LC . There is some under the pillion seat if you don't have the audio unit and a small bit in the locker(s). I carry only the bits already under the seat, the phone number for BMW Emergency Services and a credit card. I also have a puncture repair kit Velcro'd to the back of one if the panniers.
I never ride without panniers as they will save you a small fortune in the gentlest of drops. On pre LCs they stop the end can and the shaft from grounding and I have known top boxes being written off when they have touched down when the panniers are missing.
I have yet to experiment with the LC.
RTman10 wrote: Not so many cubby holes for bits on the LC . There is some under the pillion seat if you don't have the audio unit and a small bit in the locker(s). I carry only the bits already under the seat, the phone number for BMW Emergency Services and a credit card. I also have a puncture repair kit Velcro'd to the back of one if the panniers.
I do a mix of the two approaches. I very rarely ride without the panniers (even if they're empty). Not because of the [protection but because I think the bike look silly without them!
On a long ride I carry a decent tool kit, a VERY comprehensive first-aid kit and a small air compressor. Otherwise, I have a puncture kit and a small hand-pump under the seat (yes, you can inflate a tyre with it) and a Leatherman (mole grip-type) and a Motion Pro tool kit in the right-hand cubby hole.
Someone is bound to say "All you need is a credit card" I carry a little more. Do not ride with panniers on but have a soft BMW bag on the back. In bag carry compressor, Stop N Go tyre repair kit, a few zip ties, gaffer tape, a pair of disposable gloves and a small tool kit. So far all I have used is the puncture repair kit which worked a treat. Also essential is break down cover.
Forgot I also have a small First Aid kit jammed under the top box rack.
Gentlemen's hardware.
Still deciding on what else to carry, only ever done short trips before purchase of RT, now intending to do some camping touring, starting in May with a trip to the memorial sites in Northern France.
Marty
Marty
RTman10 wrote: Forgot I also have a small First Aid kit jammed under the top box rack.
That's where my Autocom is...
- timminator
Thanks all. I took a look at the tool bag I carry around in my Vespa GTS300, and I had more than I thought. Guess I need to figure out a way to sprinkle these goodies around in the RT, or tie the bag securely into the cargo cases.
BMW MOA #210438
timminator wrote: Thanks all. I took a look at the tool bag I carry around in my Vespa GTS300, and I had more than I thought. Guess I need to figure out a way to sprinkle these goodies around in the RT, or tie the bag securely into the cargo cases.
Looks like a good assortmemt, but I would lose the mitre saw ^-^
Looking back at this thread about a Torx Set, https://1200rt.com/index.php?topic=978.0, it may be surprising what few tools are required for an RT.timminator wrote:Guess I need to figure out a way to sprinkle these goodies around in the RT, or tie the bag securely into the cargo cases.
I carry sufficient tools to remove plastics & wheels.
Not forgetting your BMW Breakdown Cover, Credit/Debit Card & Mobile Phone.
Gold
- timminator
LOL @Tango! :))
Of course I always carry a mitre saw, and a wide selection of lumber. That way I can build a quick shelter if it's raining and I need to change a tire.
BMW MOA #210438
Not a lot you can work on with common tools on a RT or any modern BMW for that matter
I've got a mini snap on ratching scew driver, carry the common size torx bits, a Philips and flat blade bit in handle
Small leatherman tool
Some zip ties
That's it
Some zip ties
That's it
