Is Mahle the same as OEM parts
Re: Is Mahle the same as OEM parts
Well that means then that my dealer installed the wrong filter.
Another reason NOT to use them anymore.
2014 R1200RT-LC
Not until he swapps it for the correct one.
- Been liked: 280 times
Alfred, dare I ask which oil you used.
Very expensive fully synthetic Liqui Moly 4T synth 5W-40 Street Race.DaygloDavid wrote: Alfred, dare I ask which oil you used.
2014 R1200RT-LC
That's a new one on me, it hasn't got BMW (Shell) stamped on it, but at least it's made in Germany. (Didn't know that Germany had any oil fields.)Alfred wrote:Very expensive fully synthetic Liqui Moly 4T synth 5W-40 Street Race.
Ring another dealer and ask them what oil they use. Then get really mad with the one that put that in your sump. Looks like the correct grade though, but no idea what quality
Sounds like Alfred is doing his own oil & filter change, not a BMW dealer.Alfred wrote:The Oil Filter I just took off.
CorrectDaygloDavid wrote: Sounds like Alfred is doing his own oil & filter change, not a BMW dealer.
The dealer put shit oil and wrong filter on it. I am sick of paying for rubbish.
Liqui Moly is top of the line oil, but also comes attached with a matching price tag. Over here in Australia getting 5W-40 oil that is also MA2 is next to impossible to get. Fortunately I located an Internet Whole Seller who imports the oil.
2014 R1200RT-LC
As is says on the tin, the Liqui Moly is synthetic, API SM & JASO MA-2.
The BMW (Shell) Advantec stuff is systhetic, API SN & JASO MA-2.
The BMW spec. is API SL & JASO MA-2, therefore, both the above oils meet & exceed the requirements.
My Rider's manual says :DaygloDavid wrote: As is says on the tin, the Liqui Moly is synthetic, API SM & JASO MA-2.
"Additives (eg molybdenum-based) are not permissible because they can attack coated components of the engine..."
Does this mean we should worry about using an oil called "Liqui Moly" ?
No, it's just a brand name, https://pim.liqui-moly.de/pidoc/P000261 ... 0.0-en.pdfgogs01 wrote:My Rider's manual says :
DaygloDavid wrote: No, it's just a brand name, https://pim.liqui-moly.de/pidoc/P000261 ... 0.0-en.pdf
