Helmet to bike and(?) GPS
Oscar Nelsen
Post by Oscar Nelsen »
I need to link my Bluetooth helmet to the audio system, but I also have a Navigator V. Do I just link my helmet to the bike or do I have to link to the GPS also?
2016 RT
Re: Helmet to bike and(?) GPS
You need to link both.
Oscar Nelsen
Thank You.  I'm a Bluetooth virgin, but I am certain it's not rocket science.
2016 RT
trickstercop
Post by trickstercop »
Watch this guys video it should be helpful to you.
https://youtu.be/M_qK1zzhh-A
smileymiley
Has liked: 4 times
Been liked: 11 times
Post by smileymiley »
Oscar Nelsen wrote: Thank You. I'm a Bluetooth virgin, but I am certain it's not rocket science.
Sometimes it seems it! :shirty: :clap:
T6pilot
Post by T6pilot »
Oscar,
Your not alone
First pair helmet with bikes audio
Then pair helmet with GPS
Finally if you wish pair GPS with phone,
Oscar Nelsen
First let me say that after tasting other RT related forums, this is the best.
OK. Please correct/confirm the following:
Phones, GPS, etc. are nowhere in the vicinity.
Mine is paired to Audio as Helmet 1
Wife's as Helmet 2
My helmet gets paired to Navigator V not necessarily with it mounted to the bike
Pairing the helmets to each other is not required as they are paired via the bike's Audio.
2016 RT
T6pilot
Post by T6pilot »
What Bluetooth system?
BMW system, helmet to helmet pairing for intercom
Oscar Nelsen
Schuberth SRC System Pro
2016 RT
Just in case your dealer has not told you.  The audio system will only fully connect with the BMW headsets.  On all other makes it will only connect with one helmet  Obviously doesn't matter if you ride solo.
Oscar Nelsen
One can only guess on how many hours of troubleshooting that little tidbit has saved.  Maybe even a curse or three.
2016 RT
Oscar Nelsen
How to connect 2 Schuberth SRC helmets to RT, Nav V and phone
‘Chris on the Street’ has a collection of YouTube videos that are quite informative. The Bluetooth one, suggested above by trickstecop, gives an very thorough overview and is a great primer.
For the nuts and bolts of how to actually accomplish his setup I found these 2, which are both under 3 minutes (great for my ADD). One is by Schuberth and the other, by Richard Battles, is what I would rate a perfect 10. The audio is a music track, but the instructions could not be clearer or more precise.
https://www.youtube.com/watch?v=q8Kb9Tzj5A8
https://www.youtube.com/watch?v=fElxL_NZN-w
I did try to pair Helmet 2 to my wife’s SRC and got a Not Allowed message.
Thanks to all who have contributed to this thread and I hope this may help others who are as in the dark as I used to be.
2016 RT
Oscar Nelsen
One aspect of the SRC that I painfully became aware of is when you download new software you must then run the Reset Pairing procedure. Without doing so, I lost the bike's radio even though the SRC was still paired and successfully(?) re-paired to the bike. Although I figured it needed to be done, I did not know the procedure is not the same as in the online manual or Schuberth's video. In the old manual the steps are easy to find in its own section; in the current manual, its somewhat hidden in Troubleshooting.
The indication that a reset is necessary is the dot & Bluetooth symbol will flash instead of constantly displayed.
2016 RT
