Page 1 of 6
2012 Twin Cam - Service Costs
Posted: Wed Aug 03, 2016 12:03 pm
by David.
My 2012 TC will be due an annual service soon, having spoken to a local BMW dealer, they have offered to do an engine oil & filter change, plus final drive oil change for a very reasonable labour only rate, I will supply the oils & parts etc.
I'll probably leave the service a little longer until the bike has done nearly 6,000 miles since it's last service, then have the valve clearances & engine synchronization checked.
The BMW dealer offers a FOC visual health check which ticks all the boxes from an inspection point of view.
Does anyone know how much it is likely to cost to have the additional 2 items completed at 6,000 miles.
Re: 2012 Twin Cam - Service Costs
Posted: Wed Aug 03, 2016 1:07 pm
by Sullivj
If it helps David, I just had oil, filter, synchronisation, FOC visual check and valve clearance check for £252 at a main dealer, on my 2012 Twin Cam.
Posted: Wed Aug 03, 2016 2:41 pm
by David.
Thanks John, I'm looking at labour only, have been quoted £68 for oil & filter, (plus final drive oil change FOC).
Does your invoice breakdown the cost of parts/labour.
Posted: Wed Aug 03, 2016 3:10 pm
by guest2360
For £68 many dealers wouldn't let you through the workshop doors.  Don't forget to give them a tip.
Posted: Wed Aug 03, 2016 3:44 pm
by Sullivj
DaygloDavid wrote: Thanks John, I'm looking at labour only, have been quoted £68 for oil & filter, (plus final drive oil change FOC).
Posted: Wed Aug 03, 2016 7:35 pm
by David.
That's a great help thanks John.
The unit cost for labour (AW) is £7.80 + 20% VAT.
The BMW Service + Engine oil change, with filter is £65.52, I've been quoted £68.00, seems reasonable.
The Valve Clearance check is £37.44 + Engine synchronization at £74.88 = £112.32, will be interesting to see what my local BMW dealer comes back with.
What the invoice does confirm is that items with service codes can be requested & priced individually.
Posted: Wed Aug 03, 2016 8:19 pm
by guest2360
All service invoices from BMW dealers should always break down items by codes and unit cost.
Posted: Wed Aug 03, 2016 8:50 pm
by David.
If the unit cost (AW) is 10.00, would this be an hours labour at £93.60 inc. VAT.
The National Minimum Wage is £7.20 per hour, to pay the BMW Monkeys 1 hour, you'd have to work for 16.25 hours after tax.
It's daylight robbery!
Posted: Wed Aug 03, 2016 9:20 pm
by Sullivj
DaygloDavid wrote: If the unit cost (AW) is 10.00, would this be an hours labour at £93.60 inc. VAT.
I did get a 'free' cup of coffee....!
Posted: Wed Aug 03, 2016 9:36 pm
by guest2360
It's called a labour cost but you are paying for their knowledge and the facilities needed to complete their work.  There is always an alternative, back street garages or DIY.
Posted: Wed Aug 03, 2016 11:02 pm
by David.
DIY, you know it's done properly.
Recently had my XJ650 set up using WG analysis on a dyno testing machine at £48 per hour, that's knowledge & facilities which BMW don't offer at their dealerships.
Some folks take their RTs to Hilltop for this service.
Posted: Thu Aug 04, 2016 7:20 am
by guest2360
WG analysis ?
Posted: Thu Aug 04, 2016 8:06 am
by David.
RTman10 wrote:WG analysis?
Products of combustion (exhaust gasses) from burning petrol with air.
Posted: Thu Aug 04, 2016 9:46 am
by David.
This oil, https://www.amazon.co.uk/Castrol-Power- ... ing+10w-50,
is a higher specification than Advantec Pro 15W 50 at nearly half the price.
As recommended by BMW for Boxers.
Castrol Power 1 Engine Oil 15W-50 4T 4L is available for less than £30,
https://www.amazon.co.uk/Castrol-Power- ... rol+15w-50
Posted: Thu Aug 04, 2016 11:12 am
by guest2360
No longer recommended by BMW but no doubt OK.
