where can i buy a canbus socket?
futterweasel
Re: where can i buy a canbus socket?
Post by futterweasel »
What about using posi-tap connectors or something similar crimp new female spades to the new wires and your away. Out of curiosity what make is the new horn?
ds99
Post by ds99 »
this is what is left on the bike. ie the power from the horn switch
ds99
Post by ds99 »
Been liked: 243 times
futterweasel wrote:What about using posi-tap connectors or something similar crimp new female spades to the new wires and your away.
Good idea, no cutting off of the plug, could be made good again with a little insulation tape.
https://www.youtube.com/watch?v=N64p6ndlTQ8
Scotchlok connectors do a similar job, https://www.youtube.com/watch?v=WFdVkSaHRpU used them for installing tow bar electrics on a car.
Reaper999
Post by Reaper999 »
futterweasel
ds99 wrote: this is what i have at the moment
and i want to install this instead
I have BMW part No61337159421 Horn Low brand new in the box will fit straight on to your bike and just plug in yours £20 posted (if you are in UK)
T6pilot
Post by T6pilot »
I believe you want the "male" portion of the plug, your dealer should be able to supply that
I soldered the spade connectors to the wire pigtail and attached to horn
T6pilot wrote:I believe you want the "male" portion of the plug, your dealer should be able to supply that.
I soldered the spade connectors to the wire pigtail and attached to horn.
For £8.56, this "sounds" like the best solution.
blokeonthemove
Post by blokeonthemove »
I know the BMW ones are expensive but the scotchlok connectors are not reliable with fine wire and once buried in the fairing are a real pain if they fail owing to wet or strain. I used the bare wires strengthened by a bit of solder then poked into the BMW female side and taped up on a previous GS, it works but it's a bodge, you won't be happy . You just can't fill the bike with crappy bodged up fitments.
ds99
Post by ds99 »
thanks all
i have ordered this
http://www.ebay.co.uk/itm/322351308828?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
and some of those posi-tap things, if that doesn't work.
if all else fails i will just botch it with paperclips, twisted bits of wire and gaffer tape, which is my usual method for these things. its only a horn, and i can never find the horn switch quick enough anyway, as it is located in such a stupid position on the handlebars!
Been liked: 4 times
Post by Sullivj »
It's probably too late now, but I think BMW sell them for £3.99 each. It's the last part number in the photograph.
Sullivj wrote:I think BMW sell them for £3.99 each. It's the last part number in the photograph.
That's a good price, Rainbow BMW want £9.05 for the same item, http://www.rainbowbmw.com/BMWETK/Produc ... 011902.php
Will a 3 pin GPS plug fit in a 2 pin horn socket.
Is 28 now 29 posts a world record on where to buy one little cable.
RTman10 wrote: Is 28 now 29 posts a world record on where to buy on little cable.
People buy bikes with less advice!
