factory lowered
pencile
factory lowered
Post by pencile »
I was looking at buying a 1200RT that is advertised as "factory lowered."  He told me that it sits about 2 inches lower than a stock bike.  No one really wants the bike because of this, hence the really good price.  My question is, can this be restored back to factory stock height?  If so how much work and money would it take?
Galuois
Re: factory lowered
Post by Galuois »
What year is it?
Sent from my D5503 using Tapatalk
pencile
Re: factory lowered
Post by pencile »
its a 2013
Galuois
Re: factory lowered
Post by Galuois »
I bought a used 2005 that had also been lowered at the dealership with a pair of wilbers.
I didn't like the ride, so I decided to change the shocks. I got a pair of OEM ohlins installed and sold on eBay the wilbers.
Galuois
Re: factory lowered
Post by Galuois »
Wunderlich US has the online on sale now.
Galuois
Re: factory lowered
Post by Galuois »
Öhlins*
Re: factory lowered
The factory lowered version is what is says, factory lowered.  It has different non ESA suspention and a different unheated bench seat.  It's height is 750mm I seem to recall.
Not a particularly comfortable bike due to restricted suspension movement and it's not difficult to ground bits.    Steer clear.
BBT600
Re: factory lowered
Post by BBT600 »
Is it possible to lower a standard RT by exchanging the shocks?
Re: factory lowered
Sure it is but you would loose ESA and any resale value.  The side and centre stands would also need to be modified.  Wouldn't suggest trying anything on an LC though.
smithy
Re: factory lowered
Post by smithy »
just change the springs :be happy:
Re: factory lowered
smithy wrote: just change the springsbe
But then the stands are too long...
smithy
Re: factory lowered
Post by smithy »
I cut 25mm of the bottom of my side stand re-welded the foot back on and just use a block of wood under the rear wheel in my workshop for getting it onto the centre stand.
Re: factory lowered
smithy wrote: I cut 25mm of the bottom of my side stand re-welded the foot back on and just use a block of wood under the rear wheel in my workshop for getting it onto the centre stand.
That sounds convenient...
