Page 1 of 1
Pairing Schuberth C3 Pro to '12 RT
Posted: Wed Feb 22, 2017 8:25 pm
by stablesgroup
I've run through all the steps in the manuals, watched the Youtube videos, etc. etc.  to pair and have yet to be successful. I keep getting "Unable" or "Failed".
Anyone have any tricks or advice on what I'm doing wrong?
Thanks in advance!
Re: Pairing Schuberth C3 Pro to '12 RT
Posted: Thu Feb 23, 2017 7:13 am
by guest2360
What RT is it.
Posted: Thu Feb 23, 2017 4:23 pm
by stablesgroup
It's a 2012 R1200RT w/Audio Communication package incl. Bluetooth Interface Control, Luxury Pkg. and Cruise.
Posted: Thu Feb 23, 2017 4:36 pm
by guest2360
I can only suggest you clear out all previous links from the bike and the headset and try again.  If that fails try to connect your headset to another system to try and discover if it's working.  You could try the same with your bike with a different headset.
Posted: Thu Feb 23, 2017 5:12 pm
by stablesgroup
Yeah...I just thought someone might have had the same issues pairing the C3 w/the RT's communication package. I think there's an issue between Schuberth and BMW.
Posted: Thu Feb 23, 2017 5:18 pm
by guest2360
Not that I'm aware of.
Posted: Thu Feb 23, 2017 5:29 pm
by Casbar
Think the C3 Pro is a Scala BT unit. I have paired two different Scala BT with my 2014, the older G9 and the new Packtalk, both worked and work fine.
Try one of the US RT sites and ask the question or do a search, if there is a problem, someone will have come across it.
Posted: Thu Feb 23, 2017 5:34 pm
by Casbar
So did a search and it would seem it can be done with the 2014 on RT, so not sure about the older bikes
https://forums.bmwmoa.org/showthread.ph ... ing-Issues
Posted: Thu Feb 23, 2017 5:42 pm
by guest2360
Audio unit on the 2012 bike goes back to 2010 so might have issues with a new headset.
Posted: Thu Feb 23, 2017 5:55 pm
by stablesgroup
Thanks guys! I'll take a look.
