topcase interior light
Ihbond
Post by Ihbond »
how does one remove the interior light 2016 49l Powered top case  ( i assume its either LED or COB) from the top case ?, I started to remove the last but was not sure if i had to pry from left side , front to back, etc etc..or do i need to remove interior top case....I tried finding it in the repair manual and could not
I wanted to use the power from that wire....
2016 r1200rt
Ihbond
Re: topcase interior light
Post by Ihbond »
NM, have to remove the inner shell.....
Good thing i did not force it...
Finally found it in the manual under k1600 exclusive removing top case interior lid.
2016 r1200rt
