I found on my 15 that the Z8's were good for 3000 miles and then started to cup
Switched to PR4's and never looked back
If the original poster got 7000 miles out of his Z8's he was darn conservative or lucky most on this side of the pond are lucky to get 4000 miles out of the rear tire
Unusual Tyre wear?
Re: Unusual Tyre wear?
My new bike came on Z8s and has now clocked almost 2000 miles. Next weekend I'm off on a trip which is likely to add 4000+ miles, so I have to hope that they get me home, still in one piece !
Previous experience, with oilhead / twin cam RTs, led me to come to love Michelin PR3s. They handled as well as anything else, gave confidence in the wet and lasted (much) longer than any other tyre on any bike I've ridden in the last 30 years.
As a bonus, the tread allows you to monitor wear right across the width of the tyre, unlike so many tyres which have no tread at the centre so can look worn when they're not and / or be down to the carcass before you thought they were "illegal".
gogs01 wrote: My new bike came on Z8s and has now clocked almost 2000 miles. Next weekend I'm off on a trip which is likely to add 4000+ miles, so I have to hope that they get me home, still in one piece !
I agree - PR3s are still my favourite ever, though I never had them on an RT. They were/are amazing tyres.
I thought the Z8s were ok and although I switched to PR4 GTs when the Z8s wore out, I didn't think they were that much of an improvement.
Mind you, on the GS it seems to be fashionable to slag off the OEM Anakees but I think they're alright too! I'll probably give the new Roadtec 01s a go when the Aznakees die but only to see what all the fuss is about...
- Has liked: 6 times
- Been liked: 3 times
+1 RoadTec01s offer much improved feeling over the PR3/PR4/PR4GTs I have used. RTman10 wrote: Consider Roadtec 01s. Stability is great and they look like they will last well.
Re: original post, I have not had a set of tyres last 7,000 miles, never mind with tread left... Consider yourself lucky! Peter
- Sprintgull
Wot Peter said - seriously impressive amount of tread left @ 7k miles. Mine's still on the factory fit Z8s. They are okay, but next time I'll have a go with PR4s as Michelins were so good on the K1300. Bridgestones went square in no time.
I don't wish to divert the thread from unusual tyre wear, however. As a newbi to the RT I am amazed at the fantastic handling. I have ridden sports bikes all my life and still ride a Norton 961. But I feel absolutely confident in and out of bends on my RT often to the point of almost running out of tyre, not that at 62 I push it to the limit, its just that it is so easy and sure footed to ride. The tyres I have fitted to my 2006 Rt are Michelin radial pilot road 2 180/55 ZR17 rear, and Michelin pilot road GT 120.70 front. Tyres have always been a matter for discussion/dispute and often are a personal choice. I would be astounded if changing the tyres I have fitted could improve the handling. Mark.LAF wrote: My Z8's wore just as yours did. At 7900 miles I had to take them off. They hadplenty of tread but when laying it over on either side or working the bike through fast corners each way I was scared to death. You could feel them going over those ridges each time. Not safe and they had to go.
I ran Z8's before and my only knock was the rear wears down to cords with little to no warning as there are no sipes in the center of the rear tire.
I had a set of PR3's in stock and I am so pleased with them I can not express it. They are just a pleasure to ride on.
Bite the bullet and change them out. No sense riding on tires that you can not trust in a lean, and when you feel transition from side to side that much it is a safety issue to me. I had no confidence and that is a danger riding if you do not believe your tires are going to hold in a lean over.
I can say I will never run a Z8 again as long as I live.
mentalrental wrote: I don't wish to divert the thread from unusual tyre wear, however. As a newbi to the RT I am amazed at the fantastic handling. I have ridden sports bikes all my life and still ride a Norton 961. But I feel absolutely confident in and out of bends on my RT often to the point of almost running out of tyre, not that at 62 I push it to the limit, its just that it is so easy and sure footed to ride. The tyres I have fitted to my 2006 Rt are Michelin radial pilot road 2 180/55 ZR17 rear, and Michelin pilot road GT 120.70 front. Tyres have always been a matter for discussion/dispute and often are a personal choice. I would be astounded if changing the tyres I have fitted could improve the handling. Mark.
That's because you haven't tried Roadtec 01s yet.
- Littlebriar
Keep close tabs on the Z8 rear. They will suddenly wear through to the cords.
Steve
- Been liked: 280 times
Just like this one, which would appear to have plenty of tread left.Littlebriar wrote:Keep close tabs on the Z8 rear. They will suddenly wear through to the cords.
Had the same problem with Z6's, expected to get a 1,000 miles trip out of it and ended up down to the cords.
Useful thread - thanks to everyone who contributed. I just had my 2016 RT in for it's first proper service - mileage just over 7k. I was a bit surprised when the dealer said I had unusual wear on the front tyre, with it flattening out. It's not something that ever happened on my GS so I wasn't looking for it but now I have the 'ridges' are pretty noticeable when I run my finger over it. There is still plenty of tread on both tyres but I'll be replacing them with either the PR4 GT or the Roadtec 01, depending on which my local tyre place can get in easiest.
Given that I was getting 10-12k out of the tyres on my GS, I'm a bit disappointed. But from what I have read in this thread I seem to have done pretty well to make it this far with the stock Z8s.
- Littlebriar
Like I said in response earlier, keep a close eye on the rears. The rears can very suddenly wear down to the cords. I checked them at about 8k miles and they looked fine. 300 miles later they looked like image below. I originally blamed the dealer who overinflated the tire during a 12k service but many have experienced the same thing.
Roadtec 01's are installed now and they handle great and look like they should wear well. We'll see.
[attachimg=1]
[attachimg=1]
Steve
Yes, had the same problem with Metzeler Z6's, for this reason, switched to Dunlop RoadSmart 1's, which have a tread pattern whereby the wear can be checked in the centre of the tread.Littlebriar wrote:The rears can very suddenly wear down to the cords. I checked them at about 8k miles and they looked fine. 300 miles later they looked like image below. Many have experienced the same thing.
Over 7k miles on my original set, don't wallow about, good, hard acceleration and cornering most the time, riding it like I stole it, still reckon 2k left !!!
P.S. remind me, what do you use the brakes for ???
On my 05, I always keep my tire pressure at 42 - 43 as much as possible. I know that many go below 40. I have owned the bike for about 10 years now, and do not usually see any strange tire wear. Now of course, my right hand is a bit aggressive and that takes its toll on the rear tire, but usually my tires get replaced at anywhere from 5K - 8K. Though the rear contimotion that I replaced a couple of months ago lasted 5K, the front is at 7K. They handled well at that pressure rating.
For those that seem to be experiencing scalloping or strange tire wear, I would increase your tire pressure. It very well may help.
Same problems on Z8s should have been dealt with my Metzeler long ago but sadly not :-( went to Michelin PR4s with at least predictable wear and now with RoadTec01 which are predictable and handle better than PR4s (in my view:-)) Peter
