Blanking covers for audio
michaelc2710
Has liked: 68 times
Been liked: 79 times
Post by michaelc2710 »
Has anyone utilised the audio blanks in the N/S fairing cover for anything?
exportman
Has liked: 10 times
Been liked: 47 times
Re: Blanking covers for audio
Post by exportman »
Yes
Filled them with latch buttons for my accessories.  Controls power to aux marker lights, cameras and two way.  I have a fuse panel behind the speaker blank and that is cabled to the switches before going to the accessories. Power source to the fuse unit is via a relay.
Used 12v 22mm thread SPDT 5pin locking push button switches from Amazon they are not waterproof  but so far no problems  just a little WD40  every now and then
Had to be a bit careful with the fixing  the locking rings overlap  so had to cut then down a little with a Dremel  made the into a D shape
michaelc2710
Has liked: 68 times
thanks for the idea's exportman.
Have you taken a direct supply from the battery for the relay with a switch feed from the ignition circuit?
[size=78%] [/size]
exportman
Has liked: 10 times
Post by exportman »
Hi
Yes  fused feed via relay direct from battery  relay signal from aux socket on RH Side
michaelc2710
Has liked: 68 times
great thanks for that as I was wondering about the signal
