I will. Soon as it stops raining and I can reverse it out the shed. I have discovered one interesting item. There is a switch on the left cluster marked PTT. Handbook says it's PropelThermal Torpedo. Can't wait to try that.
The Deed Is Done
Re: The Deed Is Done
- Been liked: 381 times
Are Pidcock Tours now go be rebranded from "Rideaway" to "Driveaway", wouldn't fancy following a 3 wheeled vehicle all day.
David. wrote: Are Pidcock Tours now go be rebranded from "Rideaway" to "Driveaway", wouldn't fancy following a 3 wheeled vehicle all day.
No definately Rideaway but I assure you it's quick although limited to 125mph, apparently.
When filtering, I suppose if the front end will go through, the rear will follow.
- smileymiley
- Has liked: 6 times
- Been liked: 11 times
:)) :)) :))David. wrote: When filtering, I suppose if the front end will go through, the rear will follow.
