Notch in brake/clutch lever
- timminator
- Been liked: 2 times
Curiosity has gotten the best of me. Can anyone tell me the purpose of these notches?
BMW MOA #210438
Re: Notch in brake/clutch lever
Shear points,
If you drop bike or hit something, allows the end of lever to break rather than damaging complete unit. Both are easily replaceable, though Bmw parts are $$$
- timminator
Ahhh, makes perfect sense. Thank you.T6pilot wrote: Shear points,
BMW MOA #210438
- stayingupright
The notches are for the reminder cables used with disk locks
stayingupright wrote: The notches are for the reminder cables used with disk locks
As if
- Been liked: 337 times
If crash bung panniers are fitted, are the brake and/or the clutch lever(s) likely to break.
In over 10 years of selling BMW parts I can never remember anybody needing either lever after a fall. The pots save them as much as anything.
Broke my 1600 clutch lever at the shear point during a zero speed tip over, dealer explained it was designed that way to protect the rest of the upper system, they had a supply of clutch and brake levers at about $40 each
T6pilot wrote: Broke my 1600 clutch lever at the shear point during a zero speed tip over, dealer explained it was designed that way to protect the rest of the upper system, they had a supply of clutch and brake levers at about $40 each
Now if it had been a boxer it wouldn't have happened
SO VERY TRUE
jim
- Sprintgull
Also means that you have a fair chance of being able to ride home with what's left.
