2008 RT grips mod
temesvar
Re: 2008 RT grips mod
Post by temesvar »
pockomoth wrote: I have not tried this, I was discouraged to do so by my dealer. I'm just saying it's possible. Usually, I don't mess with BMW OEM. Other brands yes, but BMW builds things to work together, think of them like Apple and everything else like Android.
Sent from my SM-G930V using Tapatalk
Your dealer was right. However, where there is a will, there is a way! I like that saying! I sure regretted getting my self into this at first.
I sure thought I can remove the rubber and save the throttle sleeve and wheel. That is where the only problem is. Left is fine, bars are 22 mm.
so any 7/8 grip will work. But now I have all sorted out. I can use any grip that fits a 1" sleeve. No, they are not heated. I don't care for that. That is where the heated gloves are used! You need the heat on the outside, not at your palm. Is just me, so if anyone doesn't agree, so be it!
Here is a pick with the two grips, old and new.
Has liked: 35 times
Been liked: 51 times
temesvar wrote: Here is a pick with the two grips, old and new.
What's the difference in circumference around those grips temesvar?
temesvar
Post by temesvar »
4 mm, I would say, Dia. Circumference x3.14 if remember well
bandytales
Post by bandytales »
temesvar wrote: All is good now, managed to make the grips replaceable, just like any other manufacturer has.
Have a 1" sleeve for throttle, and the bars are 22 mill. Most rubber grips come with 7/8 left and 1" right.
Mission accomplished! :kacsint2:
Do you have a picture of the finished article?
temesvar
Post by temesvar »
Am still working on the handle bars, so I don't have them installed.
Here is a picture with the throttle modified. Has a 7/8 ID, 1" OD and 5 1/4
long aluminum sleeve with the wheel that rolls up the throttle cables.
Stratman
Post by Stratman »
TJRL wrote: Funny how people are so different, when I replaced my 2008 with a 2015 RT I found the OEM grips to be too narrow and went straight out and fitted "Grip Puppies" to solve the problem!!
Me too! Also stopped the tingling in my fingers.
bandytales
temesvar wrote:Here is a picture with the throttle modified. Has a 7/8 ID, 1" OD and 5 1/4
temesvar
Post by temesvar »
Problem solved. This is how  grips should look like! :kacsint2:
temesvar
Post by temesvar »
When posted this thread thought will get some help on what to expect if I will try to do this mod, on several sites. Barely had a sympathizer or two, that agreed with what and why I want to do this. Most I had was comments as why give up heated grips and why change OEM BMW look! I didn't post it as "would it be OK to give up the heated grips?" or "should I pay big bucks for a new set crapy looking OEM grips?"
Anyways, if anyone wants to do it, I can say that yes, it is do able! Here is a pic. Also lowered the handle bars an inch,(didn't dare ask about that!!) so can hardly wait to take it for a spin, but is full blown winter here .
Has liked: 6 times
Been liked: 14 times
Agree with what you said and do think they look great. BUT was that an aftermarket mirror I spotted! !!!!!!!!lol
temesvar
Post by temesvar »
BoB21 wrote: Agree with what you said and do think they look great. BUT was that an aftermarket mirror I spotted! !!!!!!!!lol
Thank You! As for the mirrors, are not after market, are original GS , not sure what year. Labeled Mickey Mouse ears, bought them
on eBay from a 08RT owner that warned me they do not fit! They fit just fine, all had to do was modifie some elongated nuts to fit!
If you are looking for a set of mirrors, I would suggest https://www.ebay.com/itm/2pcs-Black-Uni ... 2749.l2649
Just ordered a set, I like the look and shape, and for $10 can't go wrong. Will they fit? They will for me:kacsint2:
I can't say that it will work for you as your model/year bike!
